[Z06] Which Battery Post is Grounded?
Old Nov 25, 2008 | 07:36 PM
Scrivs's Avatar
Scrivs
Default Which Battery Post is Grounded?
Quick question for you. I own a 2001 Z06 and I assume the negative post is the grounded terminal on the battery. But I have heard that the positive is also a grounded post on rare occasions.
Just wondering for my battery charger/tender.
Thx
Old Nov 25, 2008 | 07:39 PM
BobbyC3's Avatar
BobbyC3
From: Common courtesy and common sense are not common.
St. Jude Donor '09-'10-'11-'12-'13
Thx
Black (-) is grounded. If + is grounded so is your car
Old Nov 25, 2008 | 08:43 PM
Bill Dearborn's Avatar
Bill Dearborn
I have never heard of a GM vehicle that had a positive ground. Whoever told you that probably doesn't know much about domestic designed and built vehicles.
Bill
Old Nov 25, 2008 | 10:23 PM
Scrivs's Avatar
Scrivs
Rog..thx guys
My source was skeptical....hence the post
Thx Again
Old Nov 26, 2008 | 04:20 AM
Milan's Avatar
Milan
- is always ground
In other countries sometimes red can be ground
Old Nov 26, 2008 | 09:59 AM
dieseldave56's Avatar
dieseldave56
Default British positive ground systems
The only positve ground systems incorperated into production that I recall were the British cars and bikes to the mid sixties. 1965 Landrover, my 1937 Austin , all my 650cc Triumph M/C with Zener diodes ( remember them?) , Triumph TR3 , ect. Some how when the British started making cars , they got it backwards . Add to that concept the Lucas electronics and you had a real winner to deal with.
Old Nov 26, 2008 | 10:46 AM
hotwheels57's Avatar
hotwheels57
Actually, aside from many tractors and foreign manufactured vehicles in the '40s and '50s, there were GM/GMC vehicles with 6v positive ground. Ford and Chrysler also produced them in that configuration.
They didn't start as well and there was an issue with corrosion. Electrical gauges didn't work as well. Jump starting was a problem. It caused issues at dealerships with the confusion of both positive and negative ground. There were some 12v positive ground vehicles. Most of the positive ground systems got changed over to negative ground systems by the owners.
Old Nov 26, 2008 | 05:46 PM
dieseldave56
Default Can recall.............
Maybe its the years but I've owned so many late forties and fifties cars and trucks ( still have the stock '51 Chevy) but don't recall one being a positive ground, maybe 'cause I'm getting or cause I'd have swtiched to neg. ground immediately.[IMG][/IMG] Well , the '51 is not all stock , with 12 v and alt, open drive line , Fenton dual exhaust and twin carbs. Power Gluide behind the 235, and shortened steering colum.
Ya, ok, I went back and looked up from my old stovebolt speeded catalogs and there were GM/GMC vehicles up till mid fifties I see that had positive 6 volt grounds. But Scrivs should not have to worry about that issue in his C5, I would think.
Old Nov 26, 2008 | 10:07 PM
BobbyC3's Avatar
BobbyC3
My dad left me his '49 convertible, a classic. This isn't mine but very similar, same color even has the optional bumper grill guard.
Old Nov 27, 2008 | 04:05 AM
dieseldave56
Default excellant example ...........
My first car was a '49 deluxe two door 'torpedo' that I bought in 1967 for ten (10) dollars which is why my '51 brings me a lot of comfort. thank you BobbyC3
Old Nov 28, 2008 | 12:47 PM
ztheusa's Avatar
ztheusa
Veteran: National Guard
Thx
Not since about 1939.
Old Nov 28, 2008 | 07:00 PM
BobbyC3's Avatar
BobbyC3
Dave,
Your pic brought back some great memories for me. My day kept the '49 in the garage for six years while "restoring" it. I had a lot of fun as a 4 - 5 year old playing behind the wheel. I know, it wasn't safe
Glad you enjoyed the pic, I have a 1/18 model of it on my office shelf.
Old Nov 28, 2008 | 08:51 PM
FasterIsBetter's Avatar
FasterIsBetter
There is a group of British car owners that call themselves the Positive Earth Society. Many British cars had the positive ground, including the older Jaguars. The early E-types (XKEs, to you who don't know Jaguars) and the XKs, some of the earlier sedans, were all postive ground. But by the early 60s, Jaguar switched all of its cars over to negative ground. Many Jag owners of older cars, and other marques as well, have converted their cars over to negative ground to avoid unintended consequences of hooking things up wrong on the assumption that the car is negative rather than positive earth.
P.S. IIRC, virtually all American made cars since at least 1950 have been negative earth.
To Which Battery Post is Grounded?
