Valvoline synthetic vs. mobil 1
I haven't had any personal experience with Valvoline synthetic, as long as it meets GM4718M (which is the Corvette standard), and says so on the bottle, I'd have no issue with using it.
I always wonder, though....how does Valvoline quantify their claim?
If that's the Valvoline racing oil, I'm thinking the "4x" thing has to do with the amount of ZDDP additive. If it's 4 times the amount in Mobil 1 then it's easy to document.
That can be a little misleading though as our roller lifter LS engines don't need high ZDDP levels. The ZDDP is critical for the flat tappet guys on a new engine break-in.
I looked at a bottle of Valvoline synthetic and although it claims 4X the protection of Mobile 1, there is no mention of the GM4718M standard.
Location: Remember the average response time to a 911 call is over 6 minutes. The average response time of a .357 magnum is 1400 fps.
Valvoline is not on the current list of GM4718M Registered Products. Not saying that it is not as good, or maybe even better, just that it's not on GM's approved list.
Current List:
76 Super Synthectic Motor Oil: 5w-30,10w-30
AC Delco Full Synthetic: 5w-30
Castrol SLX Professional 4718: 5w-30
Chevron Supreme Synthetic: 5w-30, 10w-30
CITGO SUPERGUARD Synthetic: 5w30, 10w-30
Kendall GT-1 Ultimate Synthectic Motor Oil: 5w-30, 10w-30
Mobil 1: 0w-30, 5w-30, 10w-30
Northland, SynergySynthetic: 5w-30
Pennzoil Platinum Full Synthetic: 5w-30, 10w-30
Q Horsepower: 5w-30, 10w-30
Texaco Havoline Synthetic: 5w-30, 10w-30
Valvoline SynPower: 5w-30
Current List:
Last edited by El Zappo; 12-30-2008 at 06:14 PM. Reason: Valvoline SynPower 5w-30 added 12/1/2008
I would imagine GM publishes the requirements to meet the standards, and the oil companies choose whether or not to produce products that meet or exceed the standards. One the product satisfies the requirement, I would think that the companies provide evidence as such and then they are allowed to state that they meet or exceed the standard.
And BTW - I didn't see any of the Amsoil products on the list, and I know that they meet or exceed the standard, and state this fact on all of their literature and the bottles.
It seems to me it would be beneficial for Amsoil to get on the registered list. I wonder why they don't?
BTW Amsoil, which I personally like very much does not have any statements on the bottle that claims it meets the standard. On the bottles of Signature Series 100% Synthetic 0W-30 (which is the very best oil Amsoil produces for cars/light trucks) it says:
"Recommended for applications requiring the following:
SAE 0W-30 API SM/CF, SL, SJ...
ILSAC GF-4,3...ACEA A5/B5-04 - GM 4718M, 6094M, etc, etc
"Recommended" (by Amsoil in this case) is very different from having the words "Meets or exceeds GM 4718M, etc...."
Also note, there is no API emblem (starburst or otherwise). I think Red Line and Royal Purple do the same thing. It's a legal thing.
HTH
Robert - I am pretty sure that I saw the GM4781M standard on the bottle of Amsoil at SEMA this year. It could be new labeling....
I know that Amsoil's literature and their website states compliance with the GM4718M standard - here's a quote from their site -
http://www.amsoil.net/storefront/atm.aspx
APPLICATIONS:
AMSOIL Synthetic 10W-30 Motor Oil is recommended for use in gasoline engines and other applications requiring any of the listed worldwide specifications:
* API SM/CF, SL, SJ ...
* ILSAC GF-4, 3 ...
* ACEA A1/B1, A5/B5
* JASO VTW
* GM 4718M, 6094M
* Ford WSS-M2C205-A
* Daimler Chrysler MS-6395N
* VW 503.00
* ILSAC GF-4, 3 ...
* ACEA A1/B1, A5/B5
* JASO VTW
* GM 4718M, 6094M
* Ford WSS-M2C205-A
* VW 503.00
In the case of GM 4718M (and many other "specs"), it's all about the money.
I use Mobil 1 in all 3 cars 2000 Blazer which just turned 190K...96 Maxima with 36K and of course my 04 Vette with 16K. I attribute the trouble free 190K on the Blazer (engine wise that is) to using it. Only thing on or in the engine I have changed so far are the plugs/wires/hoses ! It even has the factory exhaust !
Most oil that "meets" a certain spec is never tested by anyone.
Additive companies (Lubrizol, Ethyl etc) test their additives in a number of standard basestocks.
They then sell an additive package to the Oil Companies that they certify when blended with the basestock that the oil company claims to use will pass the tests necessary to meet a spec like GM4718M.
An oil company can ask for a "meets" or "exceeds" additive package.
I suspect that Mobil 1 bought an additive package that "meets" while Valvoline bought an additive package that "exeeds"
Long story short... when I owned a 77 Corvette I used to use Quaker State. Just for the heck of it I put in Valvoline because it was on sale. This was regular dino oil back then. Well I don't know what made me do it but after I changed it and went for a drive I took off the oil cap and peered into the valve cover, well brother there was so much foam in there you would have thought I put a cup of laundry detergent in there ! I immediately went out and purchased Quaker State and a fresh oil filter and drained out the Valvoline and have never purchased any since ! Moral of the story ? If it isn't broke don't fix it ! I just can't get past the memory of that foam to purchase anything they make.
Received 1,673 Likes
I'm using Mobil 1 in all 3 of my cars that require synthetic motor oils and I never have any trouble finding it. So I think I'll stick with it.
