Exit seat feature stopped.
Old Jan 1, 2009 | 03:29 PM
jobear's Avatar
jobear
Default Exit seat feature stopped.
Noticed today that when I turned off the car to get out and removed the key the seat did not go back. Steering wheel moved but seat did not. Any Ideas ??
Old Jan 1, 2009 | 03:50 PM
RedLS1GTO's Avatar
RedLS1GTO
Wow. I didn't know anybody actually used that feature!!
Does the seat adjust still work otherwise?
Old Jan 1, 2009 | 04:09 PM
DeeGee's Avatar
DeeGee
Hows your battery? Did you lose your memory settings. You should be able to turn Easy Entry back on in the options on the DIC
Old Jan 1, 2009 | 04:12 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Agree.....I've seen other posts where the memory settings get screwed up because of issues with the battery.
Old Jan 1, 2009 | 04:24 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
I'd think that would be a strange since I had my battery completely disconnected while installing HIDs. The only thing I lost while having it disconnected for two days was the time on the radio. All seat settings, radio stations, etc were saved still set.
Old Jan 1, 2009 | 04:41 PM
DeeGee's Avatar
DeeGee
Any idea why Easy Entry would default to off?
Old Jan 1, 2009 | 04:46 PM
moserbe's Avatar
moserbe
I like that feature, comes in handy.
Old Jan 1, 2009 | 06:55 PM
jobear's Avatar
jobear
the easy entry says it is set to on.
Old Jan 1, 2009 | 07:47 PM
dobewillie's Avatar
dobewillie
other than a battery issue I'm stumped good luck
Old Jan 2, 2009 | 12:50 AM
Blue 92's Avatar
Blue 92
None at all.
The only time I've had the easy out feature not function is when I have opened the door before pulling out the key.
Old Jan 2, 2009 | 01:27 AM
DeeGee's Avatar
DeeGee
Any codes on the DIC?
Old Jan 2, 2009 | 01:44 AM
Blue 92's Avatar
Blue 92
Good place to start.
Not to ask a stupid questions but does the seat return to the "memorized" position if you manually run it back then use the memory button on the door to reset?
To Exit seat feature stopped.
