I mostly drive the Vette on the weekends, so over the course of the week the tire pressure drops from 32, to 29, etc... so about every 4 weeks I have to fill the tires, is that normal?
Maybe the "O" rings are leaking around you sensors.
This is a common issue. Check the torque on the valve stem nut. Any good tire shop can change out the O rings. I had the same issue and Discount Tire just replaced my O rings........but they do have to dismount the tires to do this.
My left front tire has been doing this. I'm glad someone else has been reporting it! HOWEVER, if I drive the car for a few miles, it goes back up! I think maybe the tire/air in the tire gets warm and expands? Is that possible???
mine does the same thing, but it sounds like it shouldn't be dropping a couple PSI over the course of the week....on another note, just finished a drive with the top off on a perfect night, doesn't get much better.
I have one wheel that drops a few psi over the week. I've tried a few turns on the not but it still leaks. The sensor is still the original so I guess it needs changing when I get the chance.
tire manufactures say 1 to 3 lbs loss over 3/4 weeks is not a problem thats why they say check tire once a month 3lbs rise is normal for heat up/my lf looses a couple lbs a month/by the way door sticker is only a guide my best handling at 80mph cruise is 3lbs over door
