View Poll Results: Centralized two tip exit or Four tip exit?!
Centralized two tip exit!
110
47.21%
Four tip exit!
123
52.79%
Voters: 233. You may not vote on this poll
Poll: C5 Diffuser by Quik Z06-Two tip exhaust or One. Your vote will decide:)
#41
Former Vendor
Again I will look into getting both made. I was thinking I wonder if we could somehow make the piece that surrounds the exhaust removeable. That way you have the same diffuser and you just get the lower piece you need to fit 2 or 4 tips. Just a thought, I dont know if it would work, but that would be the easiest solution.
#43
Senior Badass!
#46
2 looks better, but you alienate most people.
Since this is the most recent thread, I'll ask here. Won't we have to physically remove the "indented" area of the stock fascia to make this look correct?
#47
Former Vendor
That's what I had originally asked, if that piece would have to be cutout for the diffuser to look and fit the right way. Other than that, I would think we could follow those lines and make sure the diffuser has a back piece that covers the bumper.
#50
I dont think its going to be made identical to the photoshop. That is just a rough idea of what its going to look like. Im sure Quick is going to make it where it would fit a 2 tip/4 tip C5 exhaust.
#52
Former Vendor
Exactly, everyone is posting that its ugly etc, that is not what we are going to build. That was a quick photoshop to give people an idea. We will do our best to get it made where it looks as if it belongs.
#54
I think those pictures don't do justice for me to choose. The tips look huge. If they were regular size the 4 tip might look good. But to me I like the look of the 2 tip one posted here but love having the 4 tips. If the 4 tips were smaller they might fit something more similar to the 2 tip look with the extra canards.
#55
OK ALL you two tip ( or two exhuast pipe ) guys, What is the distance Between the two exhaust pipes?
A: from the License plate side on the right pipe, to the License plate side of the left pipe ?
B: what is the distance from the out side of the right pipe, to the out side of the left pipe ?
#57
#59
Speaking of the exhaust...all those voting for two tips probably have a Borla Stinger setup, right? Those tips are almost as far apart as any 4-tip configuration and would also require a very wide opening. I've only seen a couple of guys with a custom center exhaust. Modification of the exhaust seems almost inevitable to me, so maybe you should also design a way to modify it. Maybe cutting of the pipe after the mufflers and clamping / welding on a new section with the tips properly positioned. Anyway, I'm rambling.
#60
