[Z06] Tsp cam packages
Thanks,
Matt
or get new spring with the cam.
question is what do you want your car to do?
MS3 or MS4 are popular with the F body boys
I like the 228r myself. I have a 224r now
Good Luck
the Stock .243 heads purtty much dont flow will above .590 so why have a lift above .600 ? That is called OVER CAMMING. IIRC. Numbers look cool but that is about it.
for street use a 114+4 is great easy to tune and have a bit of a rumble
my cam is a 224/224 .581/.581 on 112+0 LS6 Which is about the 224r cam.
just over 400 rwhp and 405 rwtq. 4:1 93:100 octane mix with as much advance timing as I can run.
my next cam most likely will be a 224/228 .581/.588 110+4 with AFR 205 heads milled to .60 cc on 100 octane
the
TSP XS Series Camshaft: 233/239, .595"/.603" Camshaft With Your Choice of Lobe Separation.
could als be a good option
the Texas Speed Torquer v.2 Camshaft
TSP XS Series Camshaft: Torquer 2 232/234, .595"/.598" Camshaft With Your Choice of Lobe Separation.
Remember too much or too long of duration can also delay throttle response and low end torque can suffer. but once your above 3000 rpms,
your all smiles
would be my best recomondations
Great low end very good mid range upper range
very very street able
"The Texas Speed 228/228 .588/.588 114+4 or 112+4 for a more rumble
This camshaft features Comp Cams XER lobes! The XER lobes have been proven to make big horsepower & torque thanks to their aggressive ramp rates & healthy lift.
1600-6300 RPM Power Band; This is an excellent performance camshaft with a smooth idle! Custom tuning for automatic cars required
This camshaft typically gains approximately 40rwhp!"
may not be huge SEXY numbers, but your BUTT O Metter will know the differnce
If you want a real choppy drag car type lope this cam won't give you that, but remember those cams will hurt low-end and driveability, and you could overcam as AU mentioned. The 228r is a nice in between cam that is not too small and not too big.
...oh and yeah, you can get it on a 112 lsa for more lope. OR maybe even a lower lsa than that if you wanted. Lower lsa also = better lower end and less top end just so you know.
best thing to do is Call TSP, tell them exactly what you want and ask their advice. IMO, they have the best pricing on Cam packages (Cost half the price of LG cam packages as one example) and great customer service too.
BEST way to go is to get a custom grind from someone like Ed Curtis, but the 228r has pretty much universal praise as being a good cam, and again, can't beat TSP's prices on the cam package.
Yes some heads do flow very well into the low .600s or .610 or so, then again, why go to a lift higher then the heads will flow?
Plus any high lift cam with spring to support that lift, is very hard on the valve train. and really do not produce that much more hp
Some ppl put in big double springs, that have too much valve seat pressure. All components need to work together
The other question comes down to is where the heads flow at each of the lifts, .200, .300, .400, .500
with stock or even mildle ported 243 heads, keep the lift under .600 to get the most benifit of the heads and cam.
On dont forget a new timing chain when you change the cam
Good Luck
I did think at one point if I am waiting 10-14 days why not get a custom grind but I got a headache from researching this thing and am ready to be done with the ordering process.
http://videos.streetfire.net/video/C5-Z06_589132.htm
If you plan on doing the work, get ready for some busted nuckles
Your parts left yesterday and will arrive to you on Monday!
