Intake/Throttle Body
Old Jun 16, 2009 | 01:45 AM
Lancejoker's Avatar
Lancejoker
Default Intake/Throttle Body
Anybody with a fairly stock car upgrade their Intake to a Fast 90mm and a 90mm Throttle Body? Is there much to gain by doing these? I have a BP cold air intake and headers(no cats and Z06 Ti exhaust). WOuld it be worth it or overkill for me to upgrade?
Old Jun 16, 2009 | 02:03 AM
Guro305's Avatar
Guro305
Good question. I'd like to know too!
Old Jun 16, 2009 | 09:23 AM
LightFighter_GXP's Avatar
LightFighter_GXP
I would say on a Stock LS1 you would see around a 12-15 HP Gain.... on a H/C car you would see some more
Old Jun 16, 2009 | 10:05 AM
Gideon's_Test's Avatar
Gideon's_Test
If I am not mistaken, I believe that there is a slight loss of low end torque with a fairly stock LS1 when using a Fast 90/90 set-up...
Old Jun 16, 2009 | 10:25 AM
Rapid Fred's Avatar
Rapid Fred
Does that suggest that the Fast 90/90 with a set of 4:10's would really work nicely?
Old Jun 16, 2009 | 10:54 AM
Vega$Vette's Avatar
Vega$Vette
You have a LS6 intake now on your 04.
You will not see any diff with the FAST and may actually loose some performance.
TB is a waste of money.
Old Jun 16, 2009 | 12:19 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Anything bigger than a 80mm TB on a stock cubes engine is not going to show a significant power gain.
Remember Bernuoulli's principles of fluid dynamics. A fluids velocity in an enclosure (pipe or tube) is inversely relative to the cross sectional area of that enclosure. An oversized throttle body will result in a slower intake velocity and less air getting into the combustion chamber (especially at lower RPMs) The objective with any complete intake system is to match the needs of the engine by eleminating weak spots (kinks if you will) in the induction process.
Old Jun 16, 2009 | 12:28 PM
Lancejoker's Avatar
Lancejoker
Wow Radioflyer. Impressive piece of knowledge right there. Never cease to amaze me man.
Old Jun 16, 2009 | 12:58 PM
DevilMan02's Avatar
DevilMan02
Old Jun 16, 2009 | 02:32 PM
fixvet's Avatar
fixvet
I wouldn't change the TB or intake unless you've already upgraded your heads and cam. You've got a nice set up now with your CAI and Z06 TI catbacks. I've got the same thing, plus I got a second hand Hypertech tuner installed too. My car runs just fine for me, and the little extra power is nice whenever I mash the loud pedal!
Old Jun 21, 2009 | 08:46 PM
JeremiahsC5's Avatar
JeremiahsC5
If you where running a 150 shot of nitrous would the fast intake and ls2 throttle body add horsepower?
Old Jun 21, 2009 | 08:56 PM
slvr76's Avatar
slvr76
A set of headers and a tune would do much more for you on a basically stock setup than the intake and TB.
Old Jun 21, 2009 | 09:25 PM
stingraymyway's Avatar
stingraymyway
From: Out of Site...Out of Mind. Corvette: anything else is just transportation.
St. Jude Donor '09 thru '20
Yeah, but who do you trust to do a tune that won't mess up and cause the thing to start throwing all kinds of codes??
Old Jun 22, 2009 | 09:26 AM
Vega$Vette's Avatar
Vega$Vette
There are lots of reputable tuners around. Throwing codes???
To Intake/Throttle Body
