Headlight Problems
Old Jul 2, 2009 | 12:34 PM
Dan68's Avatar
Dan68
8th Gear
Default Headlight Problems
All of a sudden, the one headlight on my 2000 Vette will not open when I either turn on the headlights manually or when they go on automatically at dark. The light is on but the entire component does not open. The other headlight works fine,,,,
Old Jul 2, 2009 | 12:45 PM
Tombone's Avatar
Tombone
It sounds like your headlight control module.
I replaced mine. You can find it behind your driver’s side headlight.
Pop up your headlight and you will see it. There are two plug in's as I remember......kinda of expensive.
Tom.
Old Jul 2, 2009 | 03:29 PM
Oldvetter's Avatar
Oldvetter
IF only one doesn't work, it is probably the gear. Look at sticky.
Look here post #2
http://forums.corvetteforum.com/c5-t...with-pics.html
Old Jul 2, 2009 | 07:37 PM
dobewillie's Avatar
dobewillie
possibly the gear good luck with repair
To Headlight Problems
