[Z06] Questions about engine break in...
Old Feb 25, 2002 | 01:46 PM
Afy's Avatar
Afy
From: Waiting for a flight Trying a Peaceful State of Mind
Cruise-In II Veteran
St. Jude Donor '15
Default Questions about engine break in...
What is the maximum RPM one should keep the car under during the first 500 miles..
Since in 6th one could potentially do about twice the speed limit under 4000 rmp.. :eek::eek:
Another about engine rpm.. is how often should you vary the rpm.. constantly or lets say every 30-60 seconds?
I know next to nothing about engines.. :p::p:
:cheers:
Old Feb 25, 2002 | 02:21 PM
jerryv's Avatar
jerryv
Default Re: Questions about engine break in... (Afy)
There's really no rocket science involved. In general, vary your speed and rpm as much as possible, without putting extreme demands (ie. redlining) on the engine. During break-in, a lot of wear-patterns will be developing, on all the moving parts .. engine, trans, rear end, etc. Varying speed and rpm as much as possible helps to create broad wear patterns that, down the road, should result in a car without noises or vibrations at certain rpms.
During break-in I tried to stay off big hiways in favor of secondary roads where I could vary speed/rpm without worrying about a lot of other traffic. I kept rpms low at first, but as I progressed thru break-in, kept putting increasing demands on the engine, until by 500 miles I felt comfortable going WOT. Hope this helps. Enjoy the ride.
Old Feb 25, 2002 | 02:25 PM
stingray454's Avatar
stingray454
Also, don't "lug" the engine during break-in, meaning don't keep it in too high of a gear with very low RPMs while accelerating. Like punching it in 6th when its at 1,000 RPM isn't good for the motor.
Old Feb 25, 2002 | 10:32 PM
Afy's Avatar
Afy
St. Jude Donor '15
Default Re: Questions about engine break in... (Jerry Velders)
have now got 330 miles.. and am begining to move the rpms up.. shifting 1-2-3 in the 25-3500 rpm range... with smooth application of the throttle.. and varying speeds in 4-5-6 smoothly.. between 3500 rpm and 2500 rpm on the higher gears...
Am waiting to be able to stand on the accellerator.. :D:D:D
Old Feb 25, 2002 | 10:38 PM
Power Shifter's Avatar
Power Shifter
YO AFY how fast is 3500 in 6th :eek: be carefull till you get used to it :jester Ric
Old Feb 25, 2002 | 10:42 PM
Afy's Avatar
Afy
St. Jude Donor '15
Default Re: Questions about engine break in... (Power Shifter)
:yesnod: :yesnod:
But have only been upto about 2700 in 6th and that was about 85.. :D:D:D:D
Old Feb 25, 2002 | 11:41 PM
Power Shifter
Afy, off the topic but can't figuer out how to im you. My speakers play at start up but no sound when I down load a movie. any sugestions? Ric
To Questions about engine break in...
