Borla X Pipe. Does it worth ?
Old Dec 8, 2009 | 11:39 PM
mosimann's Avatar
mosimann
Default Borla X Pipe. Does it worth ?
Hey guys. I have an almost stock 02 Z06, only has a Vararam and I'd like to know some info about a X Pipe.
Is it a good upgrade ? Does it require a tune or something else ? Easy to install ?
I don't want to go to H/C now as I have other priorities for the new months.
Thanks !
Old Dec 8, 2009 | 11:55 PM
itzza427's Avatar
itzza427
Will help a little bit,,mainly a tiny bit more torque. Will make the car sound better if/when you get an after market muffler(cat back) system!!The stock firing order and stock H-pipe have an odd sounding idle when the mufflers produce more sound. An X really improves the idle sound. Also knocks down drone a bit as well!!
Old Dec 9, 2009 | 01:20 AM
BOTYNV1's Avatar
BOTYNV1
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
Unless you are installing other exhaust components, just wait. The difference will be lost in your stock exhaust for the most part.
Old Dec 9, 2009 | 10:14 AM
itzza427's Avatar
itzza427
This is true,,BUT it would give you an accurate alignment for your after market setup to install it with the stock mufflers first. Probably not THAT big of a deal though!! It is true that the stock mufflers would stifle most of what benefit an X would give!!
Old Dec 9, 2009 | 02:44 PM
I installed a Bassani X-pipe on my '00 mainly to help with the drone and popping I was having with my aftermarket catback exhaust. Worked great for solving those issues.
Old Dec 9, 2009 | 02:57 PM
Chicago1's Avatar
Chicago1
Worthless if your expecting HP might as well get a whole system not worh the money IMO
Old Dec 9, 2009 | 08:37 PM
Baron138's Avatar
Baron138
I kind of missed the popping after i put mine on lol
Old Dec 9, 2009 | 09:04 PM
jrose7004's Avatar
jrose7004
If you put it on with a stock catback system you're wasting your money.
Old Dec 10, 2009 | 01:49 AM
mosimann's Avatar
mosimann
I thought that the Ti exhausts were one of the best in the market.
To Borla X Pipe. Does it worth ?
