Upgrading your C5 rear with C6 Z06 guts
Old 10-31-2017, 08:57 PM
  #141
Awesome04Vette
Awesome04Vette's Avatar
Originally Posted by Bill Curlee
ALL C5 T56 trans can benifit fron the C6 parts. The C6 parts replace the clutches, beleview springs, output shafts and pinion gear SUPORT.
However, If you replace the pinion support, you will have to do a ring and pinion set up. If you skip the pinion, its easy as hell. No set up required!!
The transmission has post and articles on its own. Its a whole nother topic. YOU TUBE SEARCH and you will find a LOT on that topic. Most parts are just repair replacement but you can get steel shift forke, bronce shift fork pads 30 spline hardened output shaft or a standard spline hardned output shaft.
- C5 ragtopws6, T-56 Build (whats in my tranny?) : http://forums.corvetteforum.com/nort...-smoother.html
Thanks man! So you think this would be the move instead of doing like an RPM transmission upgrade for the diff and trans?
Old 10-31-2017, 11:50 PM
  #142
Bill Curlee
Support Corvetteforum!
Bill Curlee's Avatar
Received 2,180 Likes on 1,583 Posts
CI 6,7,8,9,11 Vet
St. Jude Donor '08
What are your goals and intended uses for the car?? How much wheel HP / Tq do you have,, plan on installing????
A full shop built trans and diff are hard to beat. If its for an every day driver that dose some spirited driving, its a waste of money.
The C6 ZO6 Parts are an EXCELLENT up=grade as it gets rid of inherently well known WEAK C5 parts.
With the installation of C6 parts, the rear is stronger but NOT bullet proof.. Neither is the well known shop built units. IF,,,,,,,,,,,, You expose the drivetrain to wheel hop/drivetrain shake, it will break a LOT of parts in short order. You have to also do things to help limit hop/shake....
Hope this helps.
BC
Old 11-01-2017, 12:53 AM
  #143
neutron82
neutron82's Avatar
Received 1,260 Likes on 1,055 Posts
the case is still a weak point, it is dinky looking when sitting next to a c6z/zr1 case... not my pics but you can see the size difference
Old 11-01-2017, 03:35 PM
  #144
Awesome04Vette
Hope this helps.
BC
Thanks for getting back to me. The car currently is heads/cam/nitrous running a 150 shot. I am making 591whp/603ft/lb. I do drive the car on the street but rarely. I use it more as a track toy for drag racing. This season my best is 10.68 @ 137.
I originally was going to do a c6z swap but it is really becoming hard for me to justify the 14-17k price point all in with everything said and done. at most I am going to throw a little more spray at it and run a 200 shot. Car is not tracked every weekend but a decent amount through out the 2018 season.
Work has slowed down a lot this year and I have some other things I would like my money to go to other then just the car so that is part of what why I do not want to spend the money doing the c6z swap.
However with that being said I am not looking to just be cheap with everything. Just looking for a good bang for the buck utilizing the resources I have. Which is why I was looking at this diff rebuild forum because my brother can very easily build a diff/trans himself as he is a mechanic by trade.
I also plan on adding the trans/diff brace this time around lol.
Old 11-01-2017, 04:01 PM
  #145
Smoken1
Smoken1's Avatar
The trans/diff brace is a good plan. I would also look into the aFe power diff mount. They come up once in awhile on the forum..
https://afepower.com/afe-power-450-4...smission-mount
Old 11-01-2017, 04:26 PM
  #146
Awesome04Vette
Ill look into that as well! Thanks!
Old 01-09-2018, 08:20 AM
  #147
Frame77
Frame77's Avatar
My clutches are done, can I just use the
C6 Z06 clutches 19132906 (need 2)
HD spring for the clutches 19132817 (need 2)
or do I have to swap other parts as well?
Old 01-09-2018, 09:08 AM
  #148
tmtraylor
tmtraylor's Avatar
You can...make sure you have evaluated the "while I am here/what I do with this car" question as to your need for the C6Z shafts.
Replacing the seals (output shaft, side cover, front o-ring) would be prudent. Good Luck!
Old 01-09-2018, 04:00 PM
  #149
SacCityCorvette
Supporting Vendor
SacCityCorvette's Avatar
Location: SacCityCorvette.com in Sacramento Ca Join us on Facebook!
St. Jude Donor '12,'13,'15,'16,'17
Hi,
I have the complete C5 to C6 Zo6 conversion kit. Has all the heavy duty parts you need , Axle Stubs, clutches, seals, Spring disc, O rings, clips if you are interested. I bought it to do the conversion to my C5 Zo6 but ended up converting to the C6 Zo6 TR6060 and Diff.
$425 shipped in lower 48
PM me if you interested.
Christian
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Old 01-09-2018, 04:15 PM
  #150
Frame77
Frame77's Avatar
Originally Posted by SacCityCorvette
Hi,
Christian
Thanks,
I already have the motive master bearing kit,so I won't need the whole package.
Old 01-09-2018, 05:55 PM
  #151
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
YES.... You can just replace the clutches & Springs if that all you need!
bc
Old 01-09-2018, 10:13 PM
  #152
SacCityCorvette
Supporting Vendor
Thanks,
There are no bearings in this kit. This kit is just the C6 Zo6 Axles stubs, Spider Gears, Clutches, Clutch Springs, seals & O rings. These parts are much stronger than C5 parts.
Christian
Old 01-29-2018, 08:39 PM
  #153
C5-Fan
C5-Fan's Avatar
Christian
Hello
Do you still have this or can you tell wher you purchased it?
Old 01-30-2018, 03:35 PM
  #154
SacCityCorvette
Supporting Vendor
Originally Posted by C5-Fan
Hello
Hi,
Sorry it is sold. I got the kit from a guy on ebay about a year ago.
Christian
Old 01-30-2018, 07:10 PM
  #155
C5-Fan
C5-Fan's Avatar
Hi,
Christian
Old 02-15-2018, 07:54 PM
  #156
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
TTT for an exaellent post!!!
Old 04-24-2018, 01:12 PM
  #157
FNBADAZ06
FNBADAZ06's Avatar
sub'd
To Upgrading your C5 rear with C6 Z06 guts
Old 07-09-2018, 01:05 AM
  #158
95vettski
95vettski's Avatar
Amazing info in this thread!
Regarding the carbon clutches the consensus is that they are superior to the stock C5 clutches, but is there anyway to indicate by how much 30%, 50% etc?
The other day I had a one wheel burnout at the track which I suspect are worn out clutches or/and broken belleville washers. Its possible I may have not wet one the tires when reversing into the water box, although I don't know for sure.
Old 07-10-2018, 03:08 PM
  #159
IRON MAIDEN
IRON MAIDEN's Avatar
Is there a recent "Parts List" for this upgrade? I recently picked up some micro polished 4.10 gears. Hoping to find a 3 rib case to build up with this threads upgrades and the 4.10's. Figured I would get all the parts in hand and then have a local diff shop build it for me. I have a Monster Clutch & 12mm torque tube I want to get installed. I also have a cage and Pfadt trans mount to install with it. Would be nice to swap in a built diff at the same time.
Old 03-28-2019, 08:30 PM
  #160
redbird555
redbird555's Avatar
I know I'm bumping an old thread but is the consensus still that you can reuse the original pinion nut? I cant find one in stock at a dealer anywhere and the original looks fine
Quick Reply: Upgrading your C5 rear with C6 Z06 guts
