[Z06] Got some CCW classics
Old Dec 18, 2009 | 01:49 PM
  #41
AU N EGL's Avatar
AU N EGL
the more I look at these wheels and the more vettes I see with these wheels the more I like them
No wonder they are called "Classic"
a few older pics:
Old Dec 18, 2009 | 02:24 PM
  #42
Lethal1's Avatar
Lethal1
Rears are 11.5 and I beleave your correct on the offset, it's the big street set up. I use a 3/8 spacer so the are a little further outside the opening, only reason I use the spacer is cause I have the car slammed and they help keep the inside barrel away from the leaf spring . Once I go coilovers I most likely won't use them anymore.
Old Dec 18, 2009 | 04:59 PM
  #43
DannyG's Avatar
DannyG
St. Jude Donor '10
How close would you say it was coming to the leaf without the spacer?
Old Dec 18, 2009 | 05:14 PM
  #44
QSZOH6's Avatar
QSZOH6
Yep...I like em too. to the OP, car looks great. Now I need to go lower the car this weekend.
Old Dec 18, 2009 | 05:56 PM
  #45
Lethal1's Avatar
Lethal1
It actually rubbed the inner barrel before I added the spacers, but that was before I had the 4 wheel alginment done too, I went a touch more aggresive than stock ZO6 speces for my ocational cone racing, but it still was too close for my comfort.
Old Dec 18, 2009 | 06:29 PM
  #46
DannyG's Avatar
DannyG
St. Jude Donor '10
Really? I'd be very interested in knowing the exact offset of your rears. I've done several 11.5"s with +51mm offset that had no inside rubbing issues. In fact, people even reported being able to retain their brake ducts on Zs.
Either way, your car looks outstanding! I have the exact same car and those are the exact wheels, except with clear anodized outers, I want to run on it. Gorgeous!
Old Dec 18, 2009 | 07:14 PM
  #47
SkyWarp's Avatar
SkyWarp
Danny i would love to see pics of your car pls. What do you guys think about the CCW LM20's? tks
Rob
Old Dec 18, 2009 | 07:42 PM
  #48
swollix's Avatar
swollix
Our cars look identical!
Old Dec 18, 2009 | 10:48 PM
  #49
QSZOH6's Avatar
QSZOH6
Yep, even got the rear tails done and the twin tip stingers. I need to paint my lower rear facia though.
Old Dec 19, 2009 | 04:41 PM
  #50
DannyG's Avatar
DannyG
St. Jude Donor '10
Rob
Car's completely stock right now, Rob... That's why I'm inquiring about offsets. The LM20's are awesome! I like them better than the Classics, actually, but just not enough to spend the extra $.
Old Dec 19, 2009 | 05:29 PM
  #51
Lethal1's Avatar
Lethal1
I really like the LM20's also.
Old Dec 19, 2009 | 06:00 PM
  #52
AU N EGL's Avatar
AU N EGL
I talk to Malissa a while ago about the LM20s, dont think they are for corvettes. the stock corvette rotors will not fit under the rim, or something like that
Old Dec 19, 2009 | 06:13 PM
  #53
SkyWarp's Avatar
SkyWarp
Thats weird there is a forum member who has them in 17''. On his C5 ZO6
Old Dec 19, 2009 | 06:16 PM
  #54
AU N EGL's Avatar
AU N EGL
Maybe I was wrong. nope I talked to her about the LM20s to fit over BBKs.
That she said no
Old Dec 19, 2009 | 08:58 PM
  #55
swollix's Avatar
swollix
That she said no
LM20's....
Old Dec 19, 2009 | 11:58 PM
  #56
sprayed1998's Avatar
sprayed1998
Well front two wheels are leaking at the seal so i'm gonna have to reseal them. Anybody have any tips on this process?
Old Dec 20, 2009 | 03:13 AM
  #57
Lethal1's Avatar
Lethal1
Are you talking where the inner and outer barrels are bolted together? or at the valve stem seal? I tore mine apart 2 years ago to repaint the centers and had to reseal the seam where the inner and outer barrels come together. CCW has a video on how to do it, let me know I can give you some advice as well, not hard at all.
To Got some CCW classics
Old Dec 20, 2009 | 05:02 PM
  #58
swollix's Avatar
swollix
Coincidentally one of my fronts is leaking. I don't know where it is leaking from though.
Old Dec 29, 2009 | 01:25 PM
  #59
DannyG's Avatar
DannyG
St. Jude Donor '10
Spray soapy water all around the seam of the center and two rim halves, and valve stem. You'll probably find your answer
Old Dec 29, 2009 | 01:26 PM
  #60
DannyG's Avatar
DannyG
St. Jude Donor '10
Could be a T1 race setup.
