Being that l have some time l was wondering how you add air in your tires? My local gas station has a pump with no gauge. I have a digital tire pressure gadget but it seems like l am not doing it properly.
What l have been doing when l add air is driving up to my local tire store and ask them.
I have a small compressor from Sears. I check the pressure around the first of each month. I use a digital gauge. Remember you want to get a cold reading on the tires so driving somewhere does heat them up some. I have stock size tires & go 30 psi front & rear...
go to harbor freight and pick up a "real" compressor. i got mine and a bunch of tools for less than $150. check their e-mail site for coupons... you'll soon be using it for all kinds of projects...
Not to mention they print adds with coupons in many car magazines as well. I always carry a pencil gauge,,and frequently check /add at the local stations that have free air,as my shop and compressor are around the back and the station ,,for now is just more convenient!! I also usually carry a plug in compressor as a back up,,mine does actually pump up the pressure,,but it IS kinda slow compared to other sources!!
There's lots of relatively inexpensive and small compressors available that will operate from a lighter socket that you can keep in the car. Most have a built-in guage but I've found those to be off a pound or two. I have always used a simple pencil type air pressure guage, usually $5 or so. Check your tires when they are cold, even driving a few miles will heat them up and give a false or higher reading. The lighter socket compressors take a lot longer to add air than the station compressors. If you are using one at a station without a gauge, and are just adding a few pounds to top off, add air in increments of a few seconds at a time. I keep 30PSI all around as per the manual. Hope this helps.
I picked up this compressor from home depot, I also upgraded to the inflator gauge shown on the same page. It's a great little addition to my garage workspace. I use a digital tire pressure gauge to check the psi. http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
I have a compressor in our garage with a 25' hose and 3 gauges, 1 digital and 2 pencil. I also carry a "Slime" car kit in the vette and a heavy duty cigarette lighter compressor that is put in what ever vehicle we take a trip in.
I have a compressor in our garage with a 25' hose and a heavy duty cigarette lighter compressor that is put in what ever vehicle we take a trip in.
in addition, if you are really ****, they make an analog gauge set up that will connect either both front or both rear ties together with the gauge so that when you add air you get the reading from both tires simultaneously to insure they are both "in balance". personally, i haven't mastered digital gauges and still use a regular analog dial gauge.
I go with a Quality Analog Gauge with built in air release. You can over fill it a bit and tap the release button to fine tune the air pressure to perfection. It's makes it super easy to get all four dead on. Not a fan of the cheap digital gauges. Maybe if it is a Snap-On or Mac built one. This not a Digital vs Analog debate. Just what I go with as others go with what works for them. Either way, get a quality guage and fill the tires yourself where ever you like.
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
Don't want to sound sarcastic but:
This is fairly simple. Get a decent gauge and air up anywhere. Then double check pressures on your DIC after rolling a bit so the sensors have a chance to get a reading. For daily driving a pound off here or there is not a HUGE deal.
Cheap, quick alternative is a good old bike tire pump and quality gauge. Since I only need to add a few pounds here and there about 15 - 25 good pumps will do it and only takes a couple minutes. Saves me the time of hauling out and starting the compressor.
