Does the cold affect your Corvette?
Old Feb 13, 2010 | 04:36 PM
oakvillec5's Avatar
oakvillec5
Originally Posted by moserbe
Increased horsepower.
Yup, the engine loves the cold weather, the tires however read low pressure and slip more.....40-50 F really helps, but then I can't put the top down!
Old Feb 13, 2010 | 05:35 PM
thebkguy's Avatar
thebkguy
It makes a squeaking noise from the engine when its cold.. i think its the timing belt. But like after 10 mins, i dont hear it anymore.
Old Feb 13, 2010 | 11:45 PM
Don't have the problem with the Check Engine light like you do. Really no problems at all with the cold - I just take it easy when first starting out until the car gets up to temp.
Old Feb 14, 2010 | 08:52 AM
peter pan's Avatar
peter pan
Life Time NCM #2196
I notice my boosted vette makes a ton more power when it is cold outside
Old Feb 14, 2010 | 09:38 AM
65 Drivr's Avatar
65 Drivr
Originally Posted by 99XTC
I've noticed that if I don't let me car warm up to atleast 80* (Oil temp), I will get a check engine light and it'll give me a P0300 code (H and sometimes C). But it'll go away once it's all warmed up
That code is a misfire code.
Do you have any mods done to the vette and how many miles are on it?
Jet-Jock's Avatar
Jet-Jock
P0300: The powertrain control module (PCM) uses information from the crankshaft position (CKP) sensors and from the camshaft position (CMP) sensor in order to determine if engine misfire is occurring. By monitoring the variations in the crankshaft rotational speed for each cylinder, the PCM is able to detect individual cylinder misfire events. A misfire rate that is high enough can cause damage to the three-way catalytic converter (TWC). The malfunction indicator lamp (MIL) will flash if converter damage conditions are present.
Other DTCs that can cause this one: P0101, P0102, P0103, P0117, P0118, P0125, P0335, P0336, P0341, P0342, P0343, P0500, P0502, P0503, P1120, P1220, P1221, or P1258.
Other conditions that required to set it:
Engine speed between 425-3000 rpm
Ignition voltage between 10-18 v
Engine coolant between +19F to -266F (notice the minus)
Fuel level more than 10 percent
Throttle angle steady within 1%
Anti-lock brake system (ABS) and traction control are not active
Transmission is not changing gears
Secondary air injection (AIR) diagnostic test is not in progress
AC clutch is in a steady state
Engine is not in fuel shut-off or in decel fuel cut-off
Anti-lock brake system (ABS) signals are not exceeding the rough road thresholds
Conditions for setting:
PCM determines that an emission type misfire is present
PCM determines that a catalyst damaging misfire is present.
First time MIL is not turned on. Second time MIL is on, freeze frame of data stored.
Most of the diagnostics are focused on a fouling spark plug.
This may help.
Old Feb 14, 2010 | 09:48 AM
Jet-Jock's Avatar
Jet-Jock
The other DTCs:
P0101 Mass Air Flow (MAF) System Performance
P0102 Mass Air Flow (MAF) Sensor Circuit Low Frequency
P0103 Mass Air Flow (MAF) Sensor Circuit High Frequency
P0117 Engine Coolant Temp (ECT) Sensor Low Voltage
P0118 Engine Coolant Temp (ECT) Sensor High Voltage
P0125
P0335 CKP Sensor Circuit
P0336 CKP Sensor Circuit Performance
P0341 CMP Circuit Performance
P0342 CMP Sensor Circuit Low Voltage
P0343 CMP Sensor Circuit High Voltage
P0500 VSS Circuit (M/T)
P0502
P0503
P1120 TP Sensor 1 Circuit
P1220
P1221
P1258 Engine Coolant Over Temperature-Fuel Disabled
Sorry the others weren't on my immediate list if you have one of them, I'll look it up in FSM.
