Why do corvettes have battery issues?
SDLong329, this video explains how to check for a parasitic drain- http://www.youtube.com/watch?v=-yPlx4MBNRU
While no battery likes to be discharged, AGM batteries like Optimas are more resilient to long periods of non-use than traditional flooded batteries. They also have the added advantage of being sealed, which is especially important for any vehicle that has sensitive electronic equipment located below the battery tray. Most of the “bad” batteries returned to us are just deeply-discharged and work fine when properly recharged. This video explains how to properly recharge a deeply-discharge AGM battery- http://www.youtube.com/watch?v=dIoaL3DWWEg
If you have any battery-related questions, I’ll do my best to answer them.
Jim McIlvaine
eCare Manager, OPTIMA Batteries, Inc.
www.facebook.com/optimabatteries
Jim McIlvaine
I'm surprised at your remark about AGMs being more resilient to longer periods dormant. Thats not the experience here I'd say. Can you explain why?
can't sell me on battery problems in corvettes (for what it is worth, i haven't ever had a problem with any of my previous or current (still have a 78 pace car that is one of the seldom driven class)). maybe i'm just lucky, but i don't really think so.
Maintaining a voltage level of at least 12.4 volts will help extend battery life. That is why battery tenders and maintainers are so beneficial for vehicles that are not driven daily. If you have any other questions, please don’t hesitate to ask.
Jim McIlvaine
Im sure there are technical reasons why they should (or do in a lab test) but thats not what seems to be stated when it periodicaly comes up. So either the subject of this post "vettes eating batteries" is valid and thats the problem or its invalid and the red tops loose it on their own. Im leaning towards the former.
Ive had a lot of cars over the years, all had conventional batteries, none were kept on a tender, and aside from stupidity (that would be me leaving a dome light on or a door open) None of them required a jump till the end of thier service life. And many sat for extended periods of time.
My vette has a red top, I keep it on a tender.
It is very easy to test how well a battery does or does not hold a charge. Charge the battery, apply a load to remove the surface charge or just let the battery rest for 24-48 hours, to allow the surface charge to dissipate on it’s own. Leave the battery disconnected from anything and monitor the voltage over time. If you do this with an Optima battery compared to most other batteries on the market, the Optima will maintain it’s voltage longer.
We don’t buy batteries to leave them on a shelf, we buy them to put in our vehicles. Because of it’s design and high-purity lead, an Optima battery has lower internal resistance. Low internal resistance means the battery can supply more current at a given voltage, which means the battery will supply more power for a longer period of time. Simply stated, it will run your stuff longer.
The problem is, if a battery is left alone too long will, it will get deeply-discharged and because an Optima has better performance in some ways, it is easier to deeply-discharge. There are plenty of people who mistakenly believe that a deeply-discharged Optima can’t be charged. We’ve all read the posts and heard the stories. One of the most important messages Optima is trying to get out is that a deeply-discharged Optima battery can be charged with what most people have in their garage. This only treats the symptom. Preventing the battery from getting deeply-discharged is the cure.
XM radio, OnStar, ipods, cell phones, GPS systems, LoJack, DVD players and huge stereos are all fantastic gadgets that many of us enjoy, but they all increase the demands on electrical systems already wired with a multitude of computer-controlled engine and suspension management functions. As a result, even if someone considers their Vette to be a “daily driver,” if their commute doesn’t allow their alternator to maintain their battery’s state of charge, they will be slowly discharged over time and battery life will be shortened as a result.
Corvettes are not unique in that regard. A good friend of mine sells BMWs in Houston and whenever our conversations turn to the subject of batteries, he almost always blurts out, “You have to drive a new BMW for at least 20 minutes to replace the energy used to start it.” I am glad to hear your RedTop is on a tender, as that will help extend battery life.
Jim McIlvaine
1. Don't confuse me with facts, ,my mind is made up.
2. No matter how well a product is designed and built, some enterprising individual will come along and find a way to use it in a manner never intended by the manufacturer, and then swear that it is/was defective.
I'll say it one more time: A battery designed for automotive starting service was never meant to be completely discharged and, as OptimaJim pointed out, must be recharged to 14.2-volts after nearly all partial discharges in order to function properly over its normal service life.
As my pappy used to say, how are we going to teach people to think logically when we insist that the sun is rising (or setting) rather than the horizon doing the moving.
