[Z06] Z06 X Pipe question
Old Apr 4, 2010 | 08:10 PM
pql-lbc's Avatar
pql-lbc
Default Z06 X Pipe question
I posted this over on the Tech section but figure I hit everyone up here as well.
Question for my CA CF brethrens:
My just purchased (last month) '02 Z06 passed CA emissions with a K&N intake and Borla Stingers. I would like to replace the OEM H Pipe with a Borla Crossover X Pipe on the Z to do away with the gurgling sound the car is making under deceleration. Would this mod cause me to fail CA emissions?
Thanks for any input fellas.
Old Apr 4, 2010 | 08:13 PM
Dennis Wilson's Avatar
Dennis Wilson
My just purchased (last month) '02 Z06 passed CA emissions with a K&N intake and Borla Stingers. I would like to replace the OEM H Pipe with a Borla Crossover X Pipe on the Z to do away with the gurgling sound the car is making under decellaration. Would this mod cause me to fail CA emissions?
Nope Not a prob.
Old Apr 4, 2010 | 08:15 PM
MTPZ06's Avatar
MTPZ06
Nope...you just can't move the location of the stock cats. These slip on after the cats, so no issue.
Old Apr 4, 2010 | 08:27 PM
BitViper's Avatar
BitViper
Acutally technically yes.. any change to any part of teh exaust system is aginst the rules..... In my last smog exam.. they wanted to look under my car.... doubt if they could tell if it was diffrent but still....
Old Apr 4, 2010 | 09:54 PM
pql-lbc's Avatar
pql-lbc
So...if a conscientious fella did peek underneath during next year's test and was observant enough to notice that I had an aftermarket X Pipe, then he would be obliged to fail me even if my smog test came out clean? Wouldn't that have applied to the Borla's as well?
Old Apr 4, 2010 | 10:15 PM
MTPZ06's Avatar
MTPZ06
Nothing south of the stock cat position requires a CARB EO#...you're good here. If they look under the car, they're looking for the stock cats. Leave those alone and you're fine.
Old Apr 4, 2010 | 10:19 PM
Dennis Wilson
Yep
Old Apr 4, 2010 | 10:30 PM
pql-lbc's Avatar
pql-lbc
Copy all. Thanks all for imparting your knowledge.
That will be the next mod then.
Old Apr 10, 2010 | 04:24 PM
pql-lbc's Avatar
pql-lbc
Stock H-Pipe out...Borla X-Pipe in!
The exhaust note is a little more refined now with the Borla X-Pipe/Borla Stingers Combo from before with just the stock H-Pipe/Borla Stingers. The gurgling and popping on decel have for the most part gone away. Although the swap was straightforward, I am rather glad I took it to the exhaust shop and did not try to tackle the install myself. It certainly was a 2-man job and you really need to have a lift instead of trying to install it lying on your back.
Next up will be the MGW shifter install...
Old Apr 11, 2010 | 01:25 AM
Paul 68's Avatar
Paul 68
I put on a Magna Flow x-pipe on my stock exhaust, quiet it up a bit. I heard x-pipe knock the sound down 3 to 5db. But x-pipe flow better and smooth everything out.
To Z06 X Pipe question
