[Z06] No Power on Drivers door 2002 Z06
Old 04-16-2010, 11:34 PM
JoeBowZ06
4th Gear
JoeBowZ06's Avatar
Default No Power on Drivers door 2002 Z06
I have no power to the drivers door. Power windows, door lock and mirrors switch do not work. No light in door controls. The passanger side works fine. Checked fuse #34, it looks fine. Any sugestions?
Old 04-17-2010, 12:28 AM
81c3
81c3's Avatar
Maybe check the wires in the boot between the body and door.
Old 04-17-2010, 01:34 AM
JoeBowZ06
4th Gear
JoeBowZ06's Avatar
Boot looks fine, No tears or damage. Removed door pannel, saw no obvious defects. Will search forum for circut diagram and trace the power to the door.
Old 04-17-2010, 10:28 AM
81c3
81c3's Avatar
Its not the boot that your concerned with. The wires inside it are flexed back and forth every time you open or close the door. Sometimes they will break in two from the over flexing. Im not concluding that this IS the problem, but it happened to me on another vehicle of mine.
Old 04-17-2010, 03:03 PM
RogerZ06
RogerZ06's Avatar
Happened to me too on driver side.
Old 04-17-2010, 08:58 PM
JoeBowZ06
4th Gear
JoeBowZ06's Avatar
My mistake! You are absolutely correct it’s the wires in the boot. I just moved the boot around and was able to turn on the lights in the driver’s door control. Thank You!
Old 12-05-2011, 01:18 PM
DevilMan02
DevilMan02's Avatar
does anyone have any pictures of what the wires connect to after removing the boot? I'm getting ready to undertake this as i've determined this is what's happening to my door as well. i'm not sure what to expect and the boot didn't readily come off. I'm always a bit nervous about yanking on stuff and breaking it.
Any pics/tips would be greatly appreciated!
Old 05-30-2012, 03:35 AM
Jondamnit
Jondamnit's Avatar
All the controls on my 1997 Coupe drivers door work except the Lock button and the lights. The DCM will be torn appart and have the relay replaced for the door lock but I'm not sure where to look for the light issue. Time to start testing with a meter? Suggestions?
Old 05-30-2012, 11:41 PM
z 0 4 life
z 0 4 life's Avatar
This happened to me about a month ago. Take off the pass side kick panel and look for a wire going into the harness that goes into the boot that isn't fully insulated. All u need Is a lil electrical tape around the wire. Seems crazy but no problems sincE. if you search you can find pics of this.
Old 06-03-2012, 08:48 AM
Jondamnit
Jondamnit's Avatar
UPDATE: Did some testing and determined that the Door module relay and power to the lights at the switch panel were fine. Bad switch panel. Picked one up on ebay for $65 and put it in last night. Door lock and panel lights are working perfectly.
Thanks for the info fellas!
To No Power on Drivers door 2002 Z06
Quick Reply: [Z06] No Power on Drivers door 2002 Z06
