dumb question but i cant find my OBD II port?
on my old z28 and trans am it was right under the steering column..i have a 2001 C5 and i wanna plug this predator in but i cant find the pprt anywhere? can someone help
Yea, I have to feel around to hook up the HPTuners; I just can't quite squeeze my body all down in there like some apparently can
It's under there. You'll have to just feel around to find it.
Pretend that you're 16, out parking with a girl in the back seat of a car and trying to undo her bra strap.
Wounded Warrior Escort '11
The OBD port is mounted so you plug into it vertically. So its sort of hanging downward although mounted. As mentioned several times, just feel for it with your hand, middle of the bottom knee bolster.
Received 19,209 Likes
'20-'21-'22-'23-'24
Remove you ignition key, drop it on the carpet, pick it up with your teeth and then rotate your head 82-degrees clockwise and there it is!
