cold start hesitation
Old Jun 3, 2010 | 02:14 PM
mdemers883's Avatar
mdemers883
Default cold start hesitation
I have a 03 z06 with about 12k miles. So far my mod is a halltech venom intake.
When I start the car in the morning, it seems to turn over a lot more than normal. When I start the car when it's warm, it fires right up instantly and without hesitation. Any idea of what the issue might be?
Old Jun 3, 2010 | 05:10 PM
SaberD's Avatar
SaberD
try some techron fuel system cleaner. sounds like it is not driven much either. how old is the gas? has it always done this or just recently?
Old Jun 3, 2010 | 06:55 PM
Jet-Jock's Avatar
Jet-Jock
What's your voltages in either condition?
Sounds like after sitting a bit and becoming cold soaked, the battery is becoming weak. When it's a restart, it's off a fresh charge.
Unless it's a condition where the engine turns over and over several revolutions before it fires, then you got other issues like fuel to look at. Have you pulled your DTCs to see if there are any relative?
Old Jun 3, 2010 | 10:04 PM
mdemers883's Avatar
mdemers883
Gas is fresh, as it's my dd. The issue seems to be recent. Voltage seems to be ok, since it reads at about 13 on a daily basis. Not sure if the starter is going for some reason. I bought the car with low mileage, but it's still an older car. I'm very new to Chevy's so I'm not familiar with any of the quirks.
Old Jun 4, 2010 | 12:44 AM
Jet-Jock's Avatar
Jet-Jock
Are you familiar with pulling the DTC codes?
If this battery is the original battery, then I'd be real suspicious it is telegraphing an impending situation for you.
Old Jun 4, 2010 | 12:26 PM
Jet-Jock's Avatar
Jet-Jock
I would suggest to you, purchase a AC-Delco Professional 78-6YR/7YR Series battery. It's around $100 dollars and comes with a free replacement warranty for 30/50 months. It is the revised spec'd battery for this vehicle by Chevy. must have 120 reserve capacity.
Old Jun 4, 2010 | 03:52 PM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
Like others have said above....
I had the SAME issue as you are observing. I found that my battery readings on the dash were ok, but in fact my battery was weak. I replaced it and my car has been starting up quickly (like when it was new).
Old Jun 5, 2010 | 11:17 AM
mdemers883's Avatar
mdemers883
Originally Posted by 8VETTE7
Dash gage readings do not tell you the state of health of the battery. With the engine running the dash gages reading is pretty much the output voltage of the alternator. Great to know it is working but tells you nothing about the health of the battery. With the key on and engine off the reading is pretty much meaningless since many circuits in the C5 are loading the battery. You need to know the voltage of the battery with no load on it. Measure the voltage directly across the battery terminals with a digital volt meter with no key in the ignition. If it's 12.5volts or less then the battery is low. Try charging it with a battery tender style charger. Once the battery is fully charged it should read between 12.7 and 12.9 volts. Disconnect the neg battery cable for at least overnight and remeasure the voltage the next morning. If it is back near 12.5 volts then the battery is on its way out as it does not hold a charge with no load attached. Alternatively have the battery load tested at your favorite parts store. Most do it free hoping they will sell you a battery if it doesn't show good.
Thanks for the detailed reply That is all new info to me, and I definitely learned from it. I'll probably hit up the local parts store and have them test the battery as you mentioned.
Old Jun 5, 2010 | 06:51 PM
warlock007's Avatar
warlock007
fuel filter regulator
To cold start hesitation
