[Z06] Russell C5/ZO6 Stainless Steel Braided Brake Line Kits Only $119.99 a set!!! The Best
Former Vendor
Hey guys check this out, we have cut a deal with Edelbrock-Russell so we can provide the Best Brake Line Kits for Corvettes to the Corvette Forum Members
These lines have a Clear Teflon Coating over the stainless braided line.
New special price, these four line kits are only $119.99 a set.
Also dont forget about SPEED-BLEEDERs for your Calipers...they make bleeding much easier and a one-man job!!!
C5/Z06 Russell SPEED-BLEEDERS $19.99 per pair...
These are Not China made junky ones...
Direct bolt-on brake hoses bring the ultimate in braking performance.
Replacing OE rubber hoses with Russell brake hoses reduce expansion for improved braking and firmer pedal feel.
Factory assembled for an easy installation, these hoses feature stainless steel braided hose with zinc-plated fittings.
Meet the guidelines of the U.S. Department of transportation(mrss-571.106)
Hose kits are made for stock applications, unless noted otherwise.
Hey guys, just an FYI on stainless braided brake lines...We have tried every brand manufacture out on the market over the last 12 years..The reason why we think the Russell Lines are the BEST is due to there CNC'd Steel Ends...Russell uses the OEM spec's to build there ends and the biggest difference is on the end which bolts to the caliper...Russell's is a square block like OEM...Which gives much more contact sufface for sealing and strengh...Russell also allows you to use the OEM bolt, which seals better in the caliper and the square OEM spec'd end...
Call Mike directly to order yours!!
Thanks,
We accept Visa, MC, Disc, Amex, Paypal and Cashiers Checks!!!
Former Vendor
That's a good deal !
Wish this deal was available 7 months ago...
I installed a set of SS brake lines last Christmas. What an improvement on brake feel. Brakes just feel like they engage right away compared to before.
Toque
Toque
Former Vendor
Former Vendor
will these lines fit C6 Z06 calipers?
going to put those on my C5 and I think I saw a "how to" showing the square ends interfering with that caliper
Former Vendor
Hi, No these will not fit, but we do have some Racing Stainless Braided Brake Lines that will work, they use a banjo style end...we have them on sale for $89.99...
Mike ,can you get me c6 z06 brake setup ? If so pm me price , shipping , and parts included. P.S. Thanks for the great service when I bought my monster stge 3 clutch off you a few months ago ....Larry
Former Vendor
Thank you!!!
