[Z06] Weird oil problem
Old Aug 22, 2010 | 05:48 PM
02EBZ06VA's Avatar
02EBZ06VA
Default Weird oil problem
I had a custom cam, valve train, Headers, Xpipe, ported oil pump and new clutch installed a 3 months ago. I took the car back to have the car retuned because it would stall out when driving with AC on. With it off It runs great. Only the first 3 minutes of driving with the AC on is the only time the car gives me trouble. When I picked the car back up my low oil message came across the screen. So before I left they put two quarts in. Now my car is taking 6 quarts oil to be at the full level. I just changed the oil a month ago and now my oil level is below the add mark on the dip stick so I just put a quart in, and pick up some more tomorrow. There is no oil on the ground under the car so I am losing alot of it somewhere.
Any Ideas????
Old Aug 22, 2010 | 08:53 PM
DSM TJ's Avatar
DSM TJ
They take 6.5 quarts to be full if I am correct?
Old Aug 22, 2010 | 09:25 PM
71corv's Avatar
71corv
St. Jude Donor '08
I always use 7 quarts when I change. I add whatever is left in the 7th bottle so I can get rid of the bottles. My 02 Zo6 has consistently taken 6.5 + quarts each change.
Gene
Old Aug 22, 2010 | 09:32 PM
mariofromnewyork's Avatar
mariofromnewyork
Late Model Domestics
Do you have a catch can? Are you running a PCV valve?
Look into your intake for oil!
Old Aug 23, 2010 | 06:37 AM
4SFED Z's Avatar
4SFED Z
You are prob hitting the pedal real hard and driving it like you stole it. As mariofromnewyork stated.....maybe increased blowby?
Old Aug 23, 2010 | 08:16 AM
02EBZ06VA's Avatar
02EBZ06VA
Yes I do like to have some fun with it. We all do.
I did not realize that the LS6 takes so much oil. I just assumed it took maybe a 1/2 quart more than my LS1 did. I guess that would be why I am running so low.
Thanks for all of the input guys.
Old Aug 23, 2010 | 10:09 AM
Kmcoldcars's Avatar
Kmcoldcars
My assumption would be that you need to get an owners manual and read it before you damage the car.
Old Aug 23, 2010 | 11:56 AM
AU N EGL's Avatar
AU N EGL
Nothing wrong with being a full quart over. so 6.5 to 7 qt would be acceptable
Old Aug 23, 2010 | 12:33 PM
ptindall's Avatar
ptindall
If you are losing oil, you are burning it. You haven't really stated how much you are losing in a certain amount of miles. You said you had to add a quart in a month. How bad of a loss that is depends upon hom many miles and how you drove it over that time. My car burns zero oil driving nice on the street but about a quart every 40 minutes on the race track.
Old Aug 23, 2010 | 08:26 PM
USAFZ06's Avatar
USAFZ06
maybe they didnt seat a valve seal all the way when they did the spring swap during your cam change
Old Aug 24, 2010 | 07:05 AM
02EBZ06VA's Avatar
02EBZ06VA
During the summer my car is a DD and I drive about 60 miles round trip to work sometimes more if I have to go to some of my other shops. After seeing that most burn a complete quart before an oil change, I am thinking that only putting in 6 quarts and burning one is my problem. I will keep track of this the next time I do an oil change with 6.5 to 7 quarts.
Again thanks for the input guys.
To Weird oil problem
