Rotor sizing ?
Old Sep 6, 2010 | 01:11 PM
steve8's Avatar
steve8
Default Rotor sizing ?
I am considering 19" wheels for the rears and am concerned about the already small rotor looking even worse.
I am satisfied with the factory stopping ability so this is an appearance mod to me, not about performance.
I have looked at the replacement d/s rotors that run about $275. These are fine as far as I am concerned. I am not willing to spend crazy money on brakes.
Is there such a thing as a cheap upgrade to a larger rotor/rotors? I assume you cannot just throw on a larger rotor in the rear without affecting the braking system?
I may just go with 18's all around and avoid this issue.
Thanks.
Old Sep 6, 2010 | 07:09 PM
Oldvetter's Avatar
Oldvetter
Here are Corvette rotors:
Rotors
Front / Rear
C5 12.8 X 1.19 inches / 12.0 X 1.02 inches
C6 Base 12.8 X 1.26 / 12 X 1
C6 Z51 13.4 X 1.26 / 13 X 1
C6 Z06 14 X 1.3 / 13.4 X 1
Old Sep 6, 2010 | 07:25 PM
8VETTE7's Avatar
8VETTE7
Old Sep 6, 2010 | 07:28 PM
0331MARINE's Avatar
0331MARINE
From: You know your drunk when you swerve to miss the tree then you realize its your air freshener! Covington Ga
I know alot of people buy the C6Z51 rear brackets so they can put bigger rotors on the rear. Not sure if it will work the same with the front brackets.
Old Sep 6, 2010 | 07:30 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Rotors
Front / Rear
Good comparison info.....thnx
Old Sep 6, 2010 | 11:38 PM
Robert 2000's Avatar
Robert 2000
I had 19s in the rear with stock brakes and I wouldnt say that it really looked bad... What doesnt do it any justice are the stock rotors and old gray calipers its so plain and boring imo. You could go with an affordable set of drilled or slotted rotors and paint your calipers. I got a killer deal on some baer eradispeed 2s and the 14 inch rotors in the rear look very nice
Rob
Old Sep 7, 2010 | 08:45 AM
j84buick's Avatar
j84buick
I agree. The Eradispeed's fillup the rear wheel quite nicely.
Old Sep 7, 2010 | 10:03 AM
steve8's Avatar
steve8
If you use these on the rears, what do you do about the fronts?
Old Sep 8, 2010 | 12:50 AM
Robert 2000
My fronts are stock size. I would prefer larger but I can still use my stock wheels
Heres a pic
To Rotor sizing ?
