Run Flat tires
Old Sep 6, 2010 | 03:55 PM
Billski's Avatar
Billski
5th Gear
Default Run Flat tires
Have a C5 Covertible with the performance package. Considering non run flat tires replacement. Does it in fact give a better ride ? Will it affect normal driving conditions ? Have Kumo on now - not pleased - did have Michelin Sport before. Anyone have experience running non run flat. Tks
Old Sep 6, 2010 | 03:57 PM
dougbfresh's Avatar
dougbfresh
Do a search, covered many times.
0331MARINE's Avatar
0331MARINE
From: You know your drunk when you swerve to miss the tree then you realize its your air freshener! Covington Ga
I was running Toyo T1R's and I loved them! I went up to a 285/40/18 in the rear and left the front stock size. The ride will be 100% better. Now I have the T1R's up front and Nitto 555r 305/35/18 in the rear.
Old Sep 6, 2010 | 03:58 PM
0331MARINE's Avatar
0331MARINE
Yeah that will work also........
Old Sep 6, 2010 | 04:00 PM
Billski's Avatar
Billski
5th Gear
Tks will do
Old Sep 6, 2010 | 04:01 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Search is your friend, Most have gotten rid of the runflat tires, The ride is so much better and it really makes the ride a lot quieter.
Most carry AAA, Cell, A compressor, A plug kit and assorted tools just in case seeing the C5 doesn't have a spare.
Mr.Bill
Old Sep 6, 2010 | 04:23 PM
Billski's Avatar
Billski
5th Gear
Tks Mr. Bill - many of the search threads indicated that the new Michelin AZP's were pretty good balance
Old Sep 6, 2010 | 10:39 PM
Yes, non-runflat tires gives a smoother ride and a lot less road noise.
Old Sep 7, 2010 | 10:43 AM
Ultimate ride's Avatar
Ultimate ride
Also a lot better handling.
Old Sep 7, 2010 | 12:23 PM
Billski's Avatar
Billski
5th Gear
Tks all - I didn't realize this was an ole thread discussion - appreciate all the comments and researched the ole threads - good stuff. Bill
Old Sep 7, 2010 | 12:46 PM
LaMagred02's Avatar
LaMagred02
I have them on my coupe.
To Run Flat tires
