[Z06] C5 Z06 Fast List Only
#221
well was back at it today car ran better since i fixed the crack in the fast 92 and I learned it a little better more seat time i'm sure i can get my ET down
ET Street 26x11.50x16 bias ply 15psi
Performance Mods: TSP Lt's, Off road X, cam, 2.5 PRC cnc'd heads, fast 92mm,VR Ramair, Monster Stage2, RPM Lv5, Tuned & 3.73
Great Lakes dragway Union Grove, Wi temp was mid 60's humidity 75% track elevation 712ft
60'............. 1.600
330'........... 4.784
660'........... 7.383
660’ mph.....95.45
1000'..........9.610
1320'..........11.489
1320’ mph… 120.72
660’ mph.....95.45
1320’ mph… 120.72
#222
Year of the Z06
Tires used on the pass 17" mickey Thompson drag radial.
Performance Mods (if any).Lt, cai,twin disc clutch.
Which catagory. Bolt on only
60'.............1.642
330'...........4.812
660'...........7.452
660’ mph...93.76
1000'..........9.709
1320'..........11.632
1320’ mph…117.09
Byron dragway 3:47 pm. 5-19-14.
660’ mph...93.76
1320’ mph…117.09
#223
Year of the Z06
660’ mph...93.76
1320’ mph…117.09
660’ mph...93.76
1320’ mph…117.09
I like byron its very laid back and friendly just wish they was open more durring the summer like GLD
#225
Would a valve spring replacement remove me from the stock c5Z list?
Bald F1's.. 2.09 60ft
https://youtu.be/I-u6BEn_ntk
#227
Year of the Z06
660’ mph...93.76
1320’ mph…117.09
660’ mph...93.76
1320’ mph…117.09
#229
Go easy on me. I just bought the car about 3 weeks ago, and this was my first time down the track with it. I only made one pass because the clutch started slipping (55k miles, likely the original clutch with no idea how the previous owner(s) drove the car). After a 2 hour drive to the track from Cape Coral, I didn't want to risk having a problem so I decided to be happy with the pass I made and park the car. I think with some seat time, and a C6Z clutch swap, I can dial in some pretty decent passes. So far I am impressed by these cars.
2001 SW Z06
Temp probably 84 degrees here in sunny south Florida
Bradenton Motorsports park 10/15/15
Mods:
Vararam B2
Nitto NT555R's
Otherwise bone stock, unless you count an iSimple iPod adapter
RT .802
60' 1.878
330' 5.188
1/8 7.944
MPH 90.16
1000' 10.286
1/4 12.261
MPH 114.43
Slip:
2001 SW Z06
Mods:
Vararam B2
Nitto NT555R's
RT .802
60' 1.878
330' 5.188
1/8 7.944
MPH 90.16
1000' 10.286
1/4 12.261
MPH 114.43
Slip:
#230
DA based on the weather data I could find from last night using a density altitude calculator puts it at 2079.
82 degrees
62% humidity
Barometer 30.04
Elevation 19ft
Edit: Found exact info for Bradenton Motorsports on 10/15/15 at 9:15PM
1416 feet.
So corrected for altitude, that equates to a 12.072 @ 116.252
Gotta throw a clutch in the car and go on a better night and start chasing the record
82 degrees
62% humidity
Barometer 30.04
Elevation 19ft
1416 feet.
#231
2001 SW Z06
Mods:
Vararam B2
Nitto NT555R's
RT .802
60' 1.878
330' 5.188
1/8 7.944
MPH 90.16
1000' 10.286
1/4 12.261
MPH 114.43
Slip:
2001 SW Z06
Mods:
Vararam B2
Nitto NT555R's
RT .802
60' 1.878
330' 5.188
1/8 7.944
MPH 90.16
1000' 10.286
1/4 12.261
MPH 114.43
Slip:
#232
Thanks. I almost feel like us '01 guys should have a separate list, at least for bone stock, and CAI/DR because we are down 20rwhp on average from the 02-04 cars. Once you start modding obviously those differences disappear, but from gauging the times on the list, it puts me at #2 out of the '01 cars behind Ranger.
#234
Dig
#235
As soon as you put a cam in the car, you are competing against monsters, and with my Cobra being my fast car, I don't want to take the Z that far.
Doing the labor to put a stock clutch in would be worth it if anyone actually gave a damn about the quickest 2001 Otherwise I'd probably just throw a centerforce in it, do the bolt ons I have planned for the future (long tubes, X pipe, tr228 cam, tune, etc) and just enjoy the car
#236
Add me to the C5 Z06 Naturally Aspirated Non-Stock Displacement (n/a 383, 402, 408, 427, etc)
2001 Z06, Street Setup 275/18 fronts / 305/19 NT05R rears 19psi... Forged LS7 427ci block "11.25:1" with Ported L92 heads & Stock LS3 Intake / Stock 90mm TB with mild cam. RPM 4L65 Swap with 3200 converter, RPM C6Z diff stock 3.42 gear. Car needs retune do to running on old tune = Lean... Launching easy off idle... Looking for bottom 10's next spring with drag pack and retune..
Great Lakes Dragaway WI... 10/16/2015
RT........ .805
60'...... 1.629
330'.... 4.554
1/8......6.996
MPH.....101.11
1000'.....9.110
1/4 ......10.888
MPH......127.71
RT........ .805
60'...... 1.629
330'.... 4.554
1/8......6.996
MPH.....101.11
1000'.....9.110
1/4 ......10.888
MPH......127.71
#237
RT........ .805
60'...... 1.629
330'.... 4.554
1/8......6.996
MPH.....101.11
1000'.....9.110
1/4 ......10.888
MPH......127.71
RT........ .805
60'...... 1.629
330'.... 4.554
1/8......6.996
MPH.....101.11
1000'.....9.110
1/4 ......10.888
MPH......127.71
#239
I feel ya, you had a good run though no doubt. 120 is a good trap and 11.4 is faster then A LOT think. Most people don't realize how fast bottom 11's - 10's are, and how elusive they can be.... You got that sheit, always next season... I was hoping after that 10.8 pass to go back around and launch harder for a 10.5, but the line built up and it was getting late...
