View Poll Results: do you run a pvc system?
no, i deleted it
10.81%
yes, i will never ever ever ever ever delete it
89.19%
Voters: 37. You may not vote on this poll
deleting your pcv system
Old Nov 7, 2010 | 07:55 PM
hatewhatownsyou's Avatar
hatewhatownsyou
Default deleting your pcv system
im considering just deleting mine, capping off the ports and putting in a breather on the fill cap. how many others have done this?
i meant "pcv" in the poll question, not "pvc" lol
Old Nov 7, 2010 | 08:10 PM
Mtlfusion's Avatar
Mtlfusion
Old Nov 7, 2010 | 08:27 PM
TraceZ's Avatar
TraceZ
What would the advantage of deleting it be?
Wouldn't deleting it result in unwanted crankcase pressure? Maybe cause oil to blow out the dipstick tube? Also wouldn't vapors come out the breather while running as well as after shut down that would cause unwanted odors?
Old Nov 7, 2010 | 08:33 PM
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
don't delete, fix it.
First you need to replace the valley cover with the '04 Z06 cover with the built in PVC valve. Then get a "good" catch can system.
Old Nov 8, 2010 | 12:27 AM
itzza427's Avatar
itzza427
No real advantage that I'm aware of for removing it!,,Why are you thinking about deleting it?? Not sure a single breather would be sufficient either,,especially if you like to get frisky on a regular basis,,and it's hard not to in a Corvette!! I too think there is more opportunity for unwanted odors!!
Old Nov 8, 2010 | 12:51 AM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
I checked yes, realizing I got it mixed up, so I goofed up.
I did spend the money to get a catch can. It is HIGHLY recommended to get one, they are well worth the money!
Old Nov 8, 2010 | 02:12 AM
Slow Z06's Avatar
Slow Z06
IF you are NA, just put a catch can in it.
Old Nov 8, 2010 | 06:07 AM
No plans to delete mine - it is there for a reason.
Old Nov 8, 2010 | 10:13 AM
rebelheart's Avatar
rebelheart
Deleting it is simply old school thinking.
Old Nov 8, 2010 | 04:24 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Your engine compartment will be covered in a light oil film after a few 1000 miles.
It makes a big mess
Peace
Chip
__________________
..................Click for
Old Nov 8, 2010 | 05:22 PM
STALION's Avatar
STALION
From: ALL governments are legalized mobsters, so doesn't matter where I live :(
Just get a catch can and you'll be fine, or catch can and breather if you like. I just emptied my catch can yesterday after approx 1000 miles...I didn't have a lot of oil but definitely enough to make me say "WOW, that was going back into my engine???"
Old Nov 8, 2010 | 08:23 PM
Dale002's Avatar
Dale002
The new 04 Z06 valley pan as mention and catch can is the ticket. In the old day we still didn't removed the pcv system because it kept the engine compartment clean and it help with gas mileage. The filter breather on one valve cover was for fresh air input and the pcv check valve would be on the other with a hose to the carb, filter base plate or intake manifold. Simple! Basically the same system today. Like toilet paper their is only so much improvement that you can do.
What ever you do don't remove. accomplish the required repairs.
Old Nov 9, 2010 | 12:11 AM
mph1972's Avatar
mph1972
St. Jude Donor '07
It makes a big mess
Peace
Chip
Got mine from Chip and it is an outstanding and well designed product!
Thanks Chip.
- Micah
To deleting your pcv system
