Question for kwiklift users
Now you guy's have give me the shakes! I found one close by that I was thinking of buying.
My C5 is lowered on stock bolts, will it bottom out? only when laying flat? I will use it as my primary parking area.
If I park on the incline how hard is it to get in and out of the Vette? I'm no kid any more.
How long is the Kwiklift, how much floor space will I need?
You mean you never bottomed out when you when you drove up or down the ramp, true? I too am lowered on the stock bolts. When I placed the Kwiklift flat on the ground and used the Layflat ramps that Kwiklift sold, I most definitely bottomed out. Here are pictures I took when it occurred (I now always leave the rear pedestals attached)
Cruise-In VI Veteran
Hello All,
My ride is also lowered and to use my Kwik Lift in the lay flat mode I cut a few 2x4's to put under the lift, and made my own ramps from 2X10's.
My ramps are aprox 2.5 feet long and I do not bottom the rockers when driving off and on the lift.
Cheers,
Kevin
Cheers,
Kevin
This is indeed an impressive solution Kevin. I considered something like this but unfortunately, due to the amount of stuff in the garage, I don't have enough room for the long lay flat ramps need (e.g. my garage door won't close)
Cheers,
Kevin
Wow an old thread of mine from two years ago. Last year I sold the kwiklift for near what I paid for it and bought a four post lift. Although the lift was very versatile the 4 post is that much more versatile. Now I have my C5 on top and project C2 underneath for the winter.
BTW, I would leave the kwiklift with the back stanchion on the casters and the front on the ground and back up onto the lift like PewtVette. As long as I was easy on the throttle it was never an issue and with no grip tape.
