The Original Corvette C5 Key Hole Covers...
Supporting Vendor
St. Jude Donor '06-'07, '13, '15
We switched only because the white rings we were using we getting to hard to come by...
Jim
Received 1,674 Likes
I've been meaning to get one of those!
#38
Supporting Vendor
We have had a ton of customers asking me "what ever happened to our Corvette C5 Painted to match Corvette C5 Painted Keyhole Covers ?"
We have been selling these things since 2006 and turns out someone who manages the web site moved them into a category where nobody would look.
Anyway, here they are for those that are looking for them...
Now you can hide that keyhole (also keeps debris out of the keyhole so when you need it, it is clean and ready to use). Our Patented design is perfectly color-matched with OEM factory paint and clear coated for a perfect finish. We have all C5 factory paint available from 1997-2004. The Invisi-Lock is made from high quality, nickel plated magnet (not some hardware store hack job) which snap into place without any modifications and can be removed just as easily if your key fob stops working.
- Built to Last - Nickel Plated, primed, painted with
base coat, and six layers of clear coat.
- Very High Quality
- OEM Paint for a perfect finish
- Easy to install
Thanks,
Jim
- Very High Quality
- Easy to install
Thanks,
Jim
