Rocker panel protector installation...
Old Nov 17, 2010 | 03:58 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Default Rocker panel protector installation...
I searched around a bit, but I couldn't find some good pictures.
I have some rocker panel protectors and because I got them used, I have no instructions. No biggie, pretty cut and dry, but do they get mounted on the rocker panel itself, or the frame?
Any help with pictures and what you did, that would be great.
Thanks,
Micah
Old Nov 17, 2010 | 04:34 PM
rpm462's Avatar
rpm462
I got a set from Chip's CCA site over on the left and he had some pretty good installation instructions there.
Here you go.
http://www.customcorvetteaccessories...protector.html
Old Nov 17, 2010 | 05:11 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
The slightly bent up part goes toward the front of the Vette -
They attatch to the frame and not the body of the rocker panel!
Pretty straight forward job - I used a little RED Loctite on the threads that go through the rocker protectors and into the frame.(I didn't want them to back out )
Thanks,matt
Old Nov 17, 2010 | 05:57 PM
mph1972's Avatar
mph1972
St. Jude Donor '07
Thanks. The info about the slightly bent up area helps. I was going to use JB Weld instead of the tacky blue stuff. Think that would be a problem? I do not plan on taking these off.
Old Nov 17, 2010 | 06:04 PM
rpm462's Avatar
rpm462
You're right...with JB Weld I don't think they'll be coming off!
Old Nov 17, 2010 | 06:24 PM
mph1972's Avatar
mph1972
St. Jude Donor '07
To Rocker panel protector installation...
