Will Z06 rear quarters fit on a Convertible?
Old 11-23-2010, 10:58 AM
VetteTechZ16
VetteTechZ16's Avatar
Default Will Z06 rear quarters fit on a Convertible?
Looking to find out if they will fit and what other additional parts would be needed... we have customer looking to replace his convertible quarters with the wider Z06s
Thanks.
Old 11-24-2010, 02:10 AM
striper
striper's Avatar
If you are asking about C5 fenders, the answer is NO. The Z06 fenders are not any wider but where they mount up top by the roof, there is a difference where they curve up to mount. I recently investigated this exact situation because I wanted to change the fender on my Z.
Old 11-24-2010, 01:21 PM
VetteTechZ16
Thanks!
Old 11-24-2010, 02:46 PM
Sinking
Sinking's Avatar
You can put a convertible fender on the Z06 by cutting off about a quarter inch from that top part and no one will ever see it.
Old 11-24-2010, 09:26 PM
ajg1915
Support Corvetteforum!
ajg1915's Avatar
St. Jude Donor '08
The Z06 & Convertible fenders are interchangable.
The coupes are not.
Old 11-25-2010, 02:36 AM
striper
striper's Avatar
I actually did know you could trim the 'vert fender but if that's the only difference you can just get the correct fender and not worry about an inept bodyman to mess things up. I was wondering if the OP thought the Z fender covered a wider tire like a C6 Z06 does. The reason I checked this out is because I wanted to put a coupe right rear fender on my Z06 to eliminate the antenna without body work, since the fender was being replaced anyway due to being backed into. I resolved it another way and now do not have an exposed antenna.
Old 11-25-2010, 07:19 AM
Glennm27
Glennm27's Avatar
Received 1,403 Likes on 610 Posts
2017 C7 of the Year Finalist
St. Jude Contributor
Thanks.
Are you asking about a C6 here? Just looking at yor avatar along with your thoughts that the Z06 rear quarter is wider.
Old 11-25-2010, 07:58 AM
AU N EGL
AU N EGL's Avatar
The coupes are not.
Look at the b-pillar area. Vert and Z06 are the same
Old 11-26-2010, 09:22 AM
ajg1915
ajg1915's Avatar
St. Jude Donor '08
Great picture of the difference between coupes and Verts / Hardtops.
To Will Z06 rear quarters fit on a Convertible?
Quick Reply: Will Z06 rear quarters fit on a Convertible?
