revmove pcm without removing the wheel?
for a pcm tune???
That is what I did last year. I had taken it out before going on vacation
to NJ & stopped by ECS in Cream Ridge, NJ & had them reprogram it.
Brought it back home & reinstalled.
Yes I pulled the wheel off first.
St. Jude Donor '08
thanks guys
It was a long shot but my car is on my driveway under 2' of snow and my jack isn't low enough to get under the car. I was hoping not to have to start it to take the pcm out. (I have to move the car to be able to get a jack under it)
back to the drawing board...
St. Jude Donor '08
??Wouldn't you need to remove the pcm to send out or hand carry
for a pcm tune???
for a pcm tune???
You may be able to get it from the top,but you will have to remove the battery and battery tray at minimum. There is a bunch of wires and vacuum hose to screw up if your not careful. It's much easier to start,move your car and remove the tire.
Wounded Warrior Escort '11
for a pcm tune???
for a pcm tune???
St. Jude Donor '08
Doug. hoping to get it out this week!
Yes,but you still have to jack the car to get it from underneath.
St. Jude Donor '08
My view is my own and everyone has their own opinion. If I was going to have my car tuned, I would have it done as a whole car, on a dyno rather than chancing trying to get it close by a mail-order tune. Yes, they will work so you might very well get a decent tune out of it, but frankly, the tuner needs the data inputs from the performance, to get the tune right. Now reading up on ChuckCow's information with his new tuning device, if I read correctly, he's extracting information from the car by scanning it, then flashes a tune update to the scanner and sends it back to you. That's cool with me...the data is there for the professional tuner too see. Otherwise, I see lots of ads on the auction site for power chips for "our" cars which most of us know are totally bogus therefore sending our PCM out for an update without knowing the data inputs, no way would I do this. Sure, shift points, redlines, fuel cutoffs can all be done via mail order but no two engines and drivetrains perform exactly the same so no one tune will work for all cars. Just my opinion.
this is just my opinion too
closest dyno tuner is 3.5 hours away and will charge me $750. just not worth it. tuning just isn't as popular here as it is in places where you guys can drive your cars the majority of the year. boohoo for me
appreciate the option. I think I will try to get that tire off. who knows maybe I'll feel better if I start her up I will try to get you a pic of all the snow on my baby tonight...pretty sad sight
This way they would know so info on your current condition.
I don't see sending my pcm in the mail for a tune when I can get a Dyno done for $400.
As I see it, each car is different from any other car and yes, a proper dyno tune may only make a couple of HP more but then again, it could identify other issues present that need to be resolved that a mail-order tune certainly isn't going to find. The tune comes out too lean and start burning valves or slightly too rich and you destroy the cats. Any number of possible things can happen when a tuner doesn't have the car in front of them and they could end up costing a whole lot more in the long run. Mail-order tunes are just fine for some things and I have no issue, but there is a limit.
St. Jude Donor '08
I got the pcm out I took a few pics of the process. If you are weak of heart about how your vette is treated, please look away I would feel really bad if I wasn't doing this in the quest to go faster this is my Canadian version of being a red neck
btw, be careful removing the actual pcm. I managed to break the base bracket. according to CF, the parts are cheap so that makes me feel better.
