Hood Liner Fix
Old Apr 30, 2011 | 07:09 PM
tomringo's Avatar
tomringo
From: Richmond VA Everyone should have a VetteGuard
Default Hood Liner Fix
Noticed today that a corner of my hood liner is pulling away from the backing. Several other places at the edge that look like its going to happen too. Probably not long for the world and will need a replace, but for now what could I use to reseal the cover to the backing together? Thanks
Old May 1, 2011 | 12:03 AM
Might try a fabric glue.
Old May 1, 2011 | 03:08 AM
jdot's Avatar
jdot
I had the same problem and nothing worked so I had my Chevy dealer order me a new one.
Old May 1, 2011 | 07:24 AM
rws.1's Avatar
rws.1
I used some Gorilla glue applied with an acid brush (small 3/8 wide bristle brush on a hollow white metal handle) It has held for 2 years.
Old May 1, 2011 | 10:12 AM
tomringo's Avatar
tomringo
I have some of both, thanks, I'll give it try.
Old May 1, 2011 | 10:54 AM
MIKER's Avatar
MIKER
Try using needle and thread to sew it together around the edges.
Old May 1, 2011 | 10:56 AM
Triton170's Avatar
Triton170
I used spray fabric glue on mine.
Spray a medium coat into the edge and let it sit about 3 or 4 minutes. Then wrap some wax paper around the edge and clamp with aligator clips and small wooden blocks. This will give you the hard pressed edge you are looking for. The wax paper keeps the glue from sticking to the blocks.
I repaired several places with this procedure and after painting it looks like a new one.
To Hood Liner Fix
