New Product Announcement and Giveaway!
Old 05-10-2011, 03:20 PM
0n2mb.racing
Former Vendor
Liked 0 Times in 0 Posts
Default New Product Announcement and Giveaway!
Hi Everyone!
First we at N2MB Racing are very proud to sign on with Corvette Forums as sponsors! We are a small group of guys with a background in drag racing and electrical engineering. We started making electronic products in 2006.
To introduce our WOT Box product to the Corvette Forum, we are going to give one away to someone who posts in this thread. To enter the drawing, just post in this thread "I'm in." or any question or comment. We'll raffle off the WOT Box after we reach 300 comments or 10 days, whichever comes later.
The WOT Box is a no lift to shift (NLTS) and two step launch controller. We have had thousands of customers around the world drop drastic time off their E.T. and cut their 60' times, while making their runs more consistent by using the WOT Box.
Here is a breakdown of the features of the WOT Box.
No-Lift to Shift: The NLTS feature makes no-lift shifting easy by cutting your engine's power for a very short period when you shift without lifting the gas. It is triggered by the cruise control clutch switch and the TPS sensor. NLTS allows the synchros in your transmission to mesh easily and the transmission to slip right into the next gear. This reduces the chance of missing a gear and damaging your transmission. It also allows you to hold boost through the shift, significantly improving your E.T.
The major benefits are:
  • Lower ETs
  • Reduced chance of missing a gear
  • More consistent, effortless shifts
  • Reduced wear on the transmission
  • Reduced chance of major transmission damage
Two Step Launch Control : The launch control works as a secondary rev limiter that is activated when you push in the clutch and then floor the gas. The RPM you set will be held until you release the clutch or the brake or transbrake on automatic transmissions. This is one of the secrets to any drag racers short times and consistency.
Three Step Launch Control: With an optional button, you can trigger a second launch control RPM that is activated after staging.
Shift Light: An optional shift LED output is available for a simple shift light.
Rev Limiter: A full-time additional rev limiter is available, if you do not have a rev limiter in your ECU or want an additional lower rev limiter. Note: the WOT box cannot raise or modify your ECU rev limiter.
Nitrous or Meth Injection control: We have an optional add-on cable that can control nitrous or meth injection solenoids directly. The Nitrous control is adjustable to spray based on RPM, TPS and clutch position. It will not spray when the launch control is active or during a no-lift shift, for safety.
All of these function can be controlled easily using our Windows software:
Installing the WOT Box is easy and only requires connecting 6 wires. As of today we have installed on a few different Corvettes and have had great success. So, we decided to jump on board with you guys. At the moment we only have vehicle specific instructions for the 1997-2004 Corvette and the 2001-2004 Corvette Z06. You can take a look at the installation here:
http://www.npcompleteperformance.com...attredirects=0
If you have a different generation Corvette and would like to help, email us and we can work with you.
If you would like to see the WOT Box in action you can check out some of these videos below:
http://www.youtube.com/watch?v=D2z8exW96l8
http://www.youtube.com/watch?v=XbD_Aaf22PY
http://www.youtube.com/watch?v=HCV8oyu4zyI
http://www.youtube.com/watch?v=-a9o5Z0LBdM
http://www.youtube.com/watch?v=AKicxIF70KY
If you would like to see more, go to Youtube and search WOTBox or N2MB and will find many more.
Most importantly, we are going to run an introductory group buy on Corvette Forum to get started. We are going to offer the WOT Box for a short time at $179, including free US shipping. That is a discount of $20 from our standard price of $199.
You can get this price by checking out following the special website below, rather than going through our main website.
http://www.n2mb.com/corvette-forum-group-buy
Thanks for taking time to read this post. We hope to be one of your favorite mods, as we have been on many other cars.
Let us know if you have any questions. Feel free to post here or email us at [email protected]
If you would like to read more, check out our website at:
http://www.n2mb.com/wotbox
Best regards,
Jay, Jon and the rest of the crew at N2MB Racing
Reviews:
Originally Posted by i8av10 View Post
First off guys let me say I'm in no way affiliated with N2MB, I just really like their products. I run the WotBox in my twin turbo corvette and couldn't be any happier with all of the extra features this thing has. When I was in the market for something that could keep my boost up between shifts, I couldn't find anything that compares to the WotBox. The thing is more afordable with more features than anything that's out there.
I run about 12/lbs of boost on the street/track. When I would shift between gears and slam the door shut on 12 psi the car would have turbo lag and also allow the racer in the other lane to get at least a car length ahead of me. Now there is instant horse power when shifting gears. My boost stays up between gears and I can pull hard all the way to the finish line. Some people who run a lower amount of boost my not notice boost lag, but after taking your car to the track the numbers will prove other wise.
For those of you that don't win a WotBox in this thread, I strongly recommend you check this product out and take advantage of the discount that's being offered. The hardware and software is very straight forward and technical support from N2MB it top notch. It seems like Jon works 24 hrs a day.
I'm already in and lovin the new performance!
http://forums.corvetteforum.com/1577658638-post133.html
n2mb.racing is offline
Old 05-10-2011, 09:01 PM
Big Duk
CF Senior Member
Big Duk's Avatar
ok im in!
Big Duk is offline
Old 05-10-2011, 09:18 PM
HERK
CF Senior Member
HERK's Avatar
I'm in.
HERK is offline
Old 05-10-2011, 09:42 PM
mpride
CF Senior Member
mpride's Avatar
Liked 2 Times in 2 Posts
I'm in for sure. I'd suggest that whoever wins this post up and let us know what they think about it.
mpride is offline
Old 05-10-2011, 09:48 PM
STL Z06
Junior Member
STL Z06's Avatar
Im in!! I just bought an 03 Z06 specifically to build and start drag racing again!!
STL Z06 is offline
Old 05-10-2011, 09:50 PM
rtpassini
CF Senior Member
rtpassini's Avatar
St. Jude Donor '11-'12
IM IN!!!!!
i just bought my c5 with a nitrous setup. it doesnt have any the "controllers" I want, so i've been looking
rtpassini is offline
Old 05-10-2011, 10:07 PM
Mr.Bill
CF Senior Member
Mr.Bill's Avatar
Location: Reno is so close to Hell you can see Sparks , State Of Confusion
Liked 15 Times in 10 Posts
St. Jude Donor '12-'13-'14
Hey Guys, Welcome to the forum.
I'm in.
Mr.Bill
Mr.Bill is offline
Old 05-10-2011, 10:08 PM
ShawnFate
CF Senior Member
ShawnFate's Avatar
i'm in.
ShawnFate is offline
Old 05-10-2011, 11:06 PM
0n2mb.racing
Former Vendor
Also, if you purchase it as part of the group buy and you are the winner, we will refund your purchase 100%.
Old 05-10-2011, 11:17 PM
ITSQUIK
CF Senior Member
ITSQUIK's Avatar
Liked 10 Times in 10 Posts
I'm in. Sounds awesome!!
ITSQUIK is offline
Old 05-10-2011, 11:18 PM
01'IndyVette
CF Senior Member
01'IndyVette's Avatar
I'm in....
01'IndyVette is offline
Old 05-10-2011, 11:29 PM
Moderator
Support Corvetteforum!
Liked 4,091 Times in 3,562 Posts
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
I'm in. Thanks for the chance to win.
Vetteman Jack is offline
Old 05-10-2011, 11:36 PM
ZFLASH
CF Senior Member
ZFLASH's Avatar
Liked 52 Times in 42 Posts
St. Jude Donor '10-'11-'12-'13-'14, '16
Oh what the heck, I'm in. L8R ZFLASH
ZFLASH is offline
Old 05-10-2011, 11:39 PM
02*C5
CF Senior Member
02*C5's Avatar
Liked 1 Time in 1 Post
yeah buddy am in for free stuff
02*C5 is offline
Old 05-10-2011, 11:45 PM
Z06Electron
CF Senior Member
Z06Electron's Avatar
I'm in
Z06Electron is offline
Old 05-10-2011, 11:50 PM
[email protected]
CF Senior Member
chris723@ptd.net's Avatar
Im In
chris723@ptd.net is offline
Old 05-11-2011, 12:21 AM
StickFigure
Junior Member
I'm in.
StickFigure is offline
Old 05-11-2011, 12:28 AM
Sinister-Z
CF Senior Member
Sinister-Z's Avatar
I'm in.
I so need one of these.
Sinister-Z is offline
Old 05-11-2011, 01:49 AM
lucky99
CF Senior Member
Liked 7 Times in 7 Posts
ok i am in
lucky99 is offline
Old 05-11-2011, 02:05 AM
JuicedZ
CF Senior Member
JuicedZ's Avatar
I'm in.
JuicedZ is offline
Quick Reply: New Product Announcement and Giveaway!
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
