C5 Seat Rebuild Kits @ JWM
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
Works with stock seat covers/foam or aftermarket replacements. If you're replacing your seat covers this kit is a must! The kit is also a great improvement for your stock seats.
If you've ever taken your stock seat covers off you have noticed the seats side bolsters do not have any support under them. So as you climb in/out of the seat, the outside bolster foam tears where it contacts the steel seat frame and quickly sags or goes flat. The steel wires in the center area cut into the foam and quickly cause the foam to sag and pinching around the hip area.
The leather looks baggy and deep wrinkles appear. This is not a good look for your Vette! This seat repair kit corrects the seat design defect where there is no support under the side bolsters and the center wires slice into the seat foam.
Included in the kit is the material for 1 seat:
· High density Upholstery foam
· Tough, wear resistant Ballistic nylon fabric to repair the cut foam.
· .25 inch jute pad to make the seat firmer
· Zip ties to replace the metal hog rings.
· Detail step-by-step instructions with photos
No special tools are required. Spray glue like 3M Super #77 or #90 to attach the pieces will be needed. This is widely available at any home improvement or crafts store.
Stop riding around with no support! Order your kit today
Pricing and Shipping Options
$39.95 plus shipping for 1 kit
Order yours here <----
$79.90 and free shipping when you order 2 kits from this link
Order 2 kits here <----
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23
Oldtimer
Post operative report !
I had this done two months ago and It makes a really big difference. The whole seat is a little firm, but with some use the firmness will fade as it settles into it's place. Great per-strike against wear & tear.
Know if anyone sells the motors for the seats? I would love to recover mine but have been looking for a set out of a parts car with good motors due to the motors and related arms and gears being broken beyond repair on mine.
