New Product! C5 Corvette No Drill Stealth Splash Guard Kit!!
#81
I must be a complete idiot. No problem mounting the front guards, but the rear is tougher. Just how hard do you have to push to get the splash guard to slide under the clip. And does the tooth part of the clip go behind the body, which is where I think it goes, or in front. Actually I can't get them to go on either way. I don't want to scratch anything by forcing it. I'm at a loss???????
#82
Platinum Supporting Vendor
No problem. You are correct the rear clips go around the body as well as the splash guards. You may be able to open the clips slightly to make some more room, but I would be careful not to loosen them too much because you want them to be tight enough to grip and hold the splash guard while driving. You can also try sliding the clips onto the splash guard first, then as one unit push the clips into place around the body.
I hope this helps, if you need more assistance just let us know.
Thanks,
Chris
__________________
#83
Hi,
Thanks,
Chris
Thanks,
Chris
#84
I sent you a PM. We can communicate on there until we get the guards on so we don't pile on the thread too much.
Thanks,
Chris
#85
Thank you for the orders! Use coupon code LANA5 to save 5% off your order!
#86
Use Coupon Code RPICHRIS5 for Immediate Savings!!
#87
C5 Corvette Splash Guard Kit - Stealth Style, No Drilling Required
This C5 Corvette splash guards kit includes four splash guards, two for the front wheels, two for the rear wheels. No drilling or glue required. These C5 Corvette splash guards use stock hole locations to mount in combination with provide clips. We provide new push clips to install the rear splash guards. The front splash guards you simply back out the two inner fender bolts, put the splash guard in place and tighten back down. Installation takes less than 10 minutes!
These splash guards are made for the C5 Corvette, they are not a universal splash guard kit. These were designed to follow the body lines of the C5 Corvette and to remain almost un-seen, yet provide protection.
This 4 piece kit will fit all 1997, 1998, 1999, 2000, 2001, 2002, 2003, 2004 C5 Corvettes, including base, coupe, convertible and Z06.
Retail: $44.95
Intro Sale Price: $39.95
In Stock here: http://www.rpidesigns.com/shop/item.aspx?itemid=1949
Retail: $44.95
#89
#90
These make a great addition to any C5 Corvette!
If you would like to visit our Online Catalog and view all of the C5 Corvette Parts
and Merchandise that we have available for sale, just click the link below...
Website Link:
RPI Designs’ C5 Corvette Online Catalog
#91
