Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Interior How-Tos
- C6 Corvette: How to Repair Loose Gas Cap Code
Step by step instructions for do-it-yourselfers...
How many have had to replace there gas cap?
In all my years and having gone threw twenty car's not once have i ever had a gas cap go on me! im sure this is another typical problem with these cars so someone please tell me what went wrong with this gas cap that it won't tighen on?
Filled the car up yesterday. Could not get the cap to stay on. Just turns and turns, nothing happens. Did a search on here and there doesn't seem to be a fix. New one is in the plan for next week.
When I am at the gas station, I often hear fuel caps clicking and chattering as each person completes the process of adding fuel to their vehicle. One good and swift clockwise turn and several clicks later, the fuel cap is secured nice and snug; maybe a few more clicks for some people - just for good measure.
I remember reading in my Lexus owners manual, where it is written that the fuel cap should be turned clockwise until one click is heard. The owner is advised not to overtighten.
Now, after consulting the 2004 Corvette owners manual, I noticed it says: " When you put the fuel cap back on, turn it to the right (clockwise) until you hear a clicking sound. Make sure you fully install the cap. The diagnostic system can determine........."
Now GM does not STRESS the importance of just turning the cap until one click is heard the way I remeber that Lexus does; but I believe the same rule should apply to EITHER vehicle.
There is a spring in the fuel cap. It is relativley sensitive. Just one or two clicks each time
you fill up is sufficeint to fasten the cap and satiisfy the emmissions system. Just one or two clicks might do well to prolong the life of the unit.
I know this doesn't help the OP now; but a word to the wise to everyone else.
The following 2 users liked this post by John1990:
El original (09-06-2017),
Yello95 (09-06-2017)
Just bought a new gas cap on ebay and i see that the seller has already sold 16 of them! only 4 left! so i see that this is a problem that is just a matter of time that everyone will need to buy a replacement.
Received 19,286 Likes
'20-'21-'22-'23-'24
Never had a problem with the gas caps in any of my Corvettes.
If you don't get the seal complete the computer can pick it up as an emissions malfunction. My hearing is not what it used to be so I don't always pick up the first click but it doesn't take a half turn either. Once you hear it click you should be good.
Well it may not be a common problem for some but I had 3 of the damn things from GM break. I finally went to NAPA a bought one of theirs. Only problem is the tether doesn't fit on it but I modified the tether to make it work. I only turned one click after the first one failed so that was not the problem.
Just replaced mine yesterday... Wouldn't tighten at all, plus I kept getting a error code.... So I spent 10 bucks for a new one at Autozone and had them clear the code hasn't been an issue since....
So tell me, what piece on your car could break without you claiming it was one more piece of GM trash?????
To the Op: the gas cap seal can go bad. I've had three or four caps need replacement on different vehicles. Not uncommon. Not expensive. Not life threatening.
St. Jude Donor '10-'12-'13-'14-'15-'16-'17
Good grief,,, Yea, just ONE MORE THING on an 8 YEAR OLD CAR that just can't stand up to the test of time or use...
Thanks,Matt
I had same problem, but on my Saturn coupe, the cap has plastic arms that are spring loaded down, just one or two clicks are needed to seal the tank fuel spout. If you ratch it another 10 or more clicks, when you try to remove it, those plastic spring arms aren't strong enough and it stops working or breaks or bends. I replace the old one and cut it open, very cheap design, no metal at all.. Good Luck.
I had issues with my gas cap 2 years ago. Once and a while it would not "click" as I turned it on. I got a new replacement from NAPA just in case. My original gas cap has not given me a problem since I got the new one. I have the new one in my trunk for the day my original one starts to mess up again.
Toque
Toque
The same cap fits other vehicles not just GM. So, no not GM specs and as others have said, problems may have more to do with the operator.??
This part also fits:
8 vehicles
1997 - 2004
Corvette
V8 - 5.7L vin G 350ci - MFI GAS OHV
1 vehicles
2005
Corvette
V8 - 6.0L vin U 364ci - MFI GAS OHV
4 vehicles
2001 - 2004
Corvette Z06
V8 - 5.7L vin S 350ci - MFI GAS OHV
Lexus 3 vehicles
2006
ES330
V6 - 3.3L 202ci 3300cc type 3MZFE - MFI GAS DOHC
1 vehicles
2006
GX470
V8 - 4.7L 285ci 4663cc type 2UZFE - MFI GAS DOHC
1 vehicles
2006
RX330
Toyota 4 vehicles
Mine crapped out also. Was still under warantee so the dealer gave me a new one. The managers exact response was " another fuel cap wtf!" lol. He said they were having problems with them. In fact he was ordering 12 of them at a time just to keep in stock.
