Tire Pressure Accuracy
Old Jul 7, 2011 | 06:58 PM
craig04c5's Avatar
craig04c5
Originally Posted by seabright
OK, Craig..... same question: Do you inflate your cold tires to 30# based on your tire gages or the TPS?
I inflate using my tire gauges. Not to confuse the issue but I also run 2# under (28 using gauges, cold) down here in the summer (May-October). When the tires heat up it gains 2#.
Old Jul 7, 2011 | 11:49 PM
LS WON's Avatar
LS WON
I just run all 4 tires at factory settings 30 PSI all around.
Old Jul 7, 2011 | 11:50 PM
ronssito's Avatar
ronssito
I suspect your Big O factory, cheap, analog gauge is spec'd at +/-1 minor increment, or in this case +/-1 psi ... meaning it could be off by 2 psi and still be in spec.
Old Jul 7, 2011 | 11:58 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I only have 1 guage I use and it is an analog one and it is dead on with the DIC, I do have new TPS I bought from Tire Rack a few months ago. If my guage says 32 the DIC also says 32.
Mr.Bill
Old Jul 8, 2011 | 12:00 AM
LS WON's Avatar
LS WON
Mr.Bill
How much did this gauge cost?
Old Jul 8, 2011 | 12:29 AM
Mr.Bill's Avatar
Mr.Bill
I believe I paid 25 bucks for it.
Old Jul 8, 2011 | 12:46 AM
LS WON's Avatar
LS WON
Old Jul 8, 2011 | 03:26 AM
Jistari's Avatar
Jistari
Mine can be one or two pounds off my hand held gauge.
Old Jul 8, 2011 | 02:35 PM
MAC5's Avatar
MAC5
That saves me from performing the same test. Thanks.
Makes sense........ MAC5, are any of your gages made by Longacre?
No both digital are AccuTire gauges. Measurements Inc. is the manufacturer name. I have no idea who makes the analog gauge.
Old Jul 8, 2011 | 02:47 PM
LS WON's Avatar
LS WON
I have the Accuguage round dial type gold in color with white face. I know it's alot better than those pen type cheapies.
Old Jul 8, 2011 | 06:21 PM
killain's Avatar
killain
Oldtimer
Default Tpms ?
I have two digital gauges that read exactly the same. One analog gauge that I'd peg at less than one pound lower than the two digitals.
I set the pressure by the digital gauges, 30 psi cold and check pressure about once every two weeks. I let the TPMS do the ALERT work if they run low.
I had County Corvette Inc. Install four new Michelin's Pilot Sports ps/2 ZP's and a new set of TPMS sensors. I set them at 30 PSI and you need to drive a few miles to allow the sensors to talk to the PCM, but I set the tire pressures with a good quality digital air pressure gauge and the sensors seem to be almost the same on the DIC and the digital gauge that I used to set the air pressure with. A hell of a lot better than the old original set, they were worn out and it was a PITA to get the DIC reading and the hand guage to read the same.
