Door window wipes
Old Jul 13, 2011 | 08:42 AM
car48nut's Avatar
car48nut
Default Door window wipes
The push in anchor rivits are loose in the window wipe on both my doors. anyone know a fix, to make the holes in the door smaller? Thanks
Old Jul 13, 2011 | 12:51 PM
guido7834's Avatar
guido7834
I have the same problem I have to take care of. I had the same thing on my 87 and I just drilled a pilot hole and fastened them using a short wafer head screw. I will have to investigate if the same can be done on my c5. After I figure out hoe to get the door panel off!
Old Jul 13, 2011 | 01:29 PM
To get the door panel off, go to the Vette Essentials web site and look under the door pull install instructions.
Old Jul 13, 2011 | 02:22 PM
guido7834's Avatar
guido7834
Thank you!
To Door window wipes
