Oil Change Question
Old Jul 21, 2011 | 04:19 PM
1timtim1's Avatar
1timtim1
Default Oil Change Question
Has anyone used those oil siphon tubes? You can shove the tube to the back of the oil pan thru the drain plug and siphon any oil out instead of jacking the back of the car up. Just wondering. Thanks!
Old Jul 21, 2011 | 04:33 PM
87SAM's Avatar
87SAM
Truthfully, I don’t worry about the couple of ounces that are left in the pan. My homemade oil changing ramps are only 4 ½” high, the amount left is miniscule.
Old Jul 21, 2011 | 04:40 PM
jrose7004's Avatar
jrose7004
Nope, I do it the old fashioned way!
Old Jul 21, 2011 | 04:49 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
i use my quik lift (the car is level) and as previously noted, don't worry about the couple of ounces that may be remaining. other than do it yourself, i would bet pretty much anything that any one changing the oil (dealer etc) is doing it off a lift with the car level also. i've been changing my own oil on all my cars for well over 50 years and i haven't ever had a problem with whatever residual few ounces might remain behind. the new oil filter should take care of it if necessary. .
Old Jul 21, 2011 | 07:44 PM
MyOwn69's Avatar
MyOwn69
Hey, it's not like you're leaving "cheap" oil in there - or oil that's been there for 10,000 - 15,000 miles, right?
Really, these "ounces" are NOT worth the sweat!
Old Jul 21, 2011 | 09:14 PM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
Me too
Old Jul 21, 2011 | 09:58 PM
1timtim1's Avatar
1timtim1
Thanks everybody!Doing it the old fashion way.
Old Jul 22, 2011 | 12:17 AM
lh4x4's Avatar
lh4x4
I just lift it and go underneath and do it like the service garage does.
But it takes awhile to get the area ready.
Old Jul 22, 2011 | 12:41 AM
OkieBikerDude's Avatar
OkieBikerDude
I've used the siphon pumps in the dipstick tube on boats for years with no problems. In those cases, getting under the engine was impossible while mounted in the boat. I believe the small amount of oil left in the engine was of no consequence; However, in my Corvette I jack up the car with the rear high and drain it while it's hot for at least one hour. Overkill? You bet and I'm proud of it.
OBD
Old Jul 22, 2011 | 07:20 AM
Must_Have_Z's Avatar
Must_Have_Z
OBD
I agree and do it the same way. Besides, the point of an "oil change" is to change all of the oil, not most of it. Call it being ****, but if you have the means, you may as well do it right.
Old Jul 22, 2011 | 07:33 AM
dquagliaroli's Avatar
dquagliaroli
Default to each their own
Old Jul 22, 2011 | 07:37 AM
runner140*'s Avatar
runner140*
No...I use RaceRamps and jack up the back end higher than the front. I get most of the old oil out.
Old Jul 23, 2011 | 10:42 AM
TOPCATHR's Avatar
TOPCATHR
Gotta change the oil filter ,may as well use the drain plug
Old Jul 23, 2011 | 10:51 AM
Oldvetter's Avatar
Oldvetter
I measured the extra oil you get out by raising the rear, it was 4 ounces. I still raise the rear, but it is not necessary. Even the shop manual says the car should be level.
Old Jul 23, 2011 | 08:29 PM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
I get all of the old oil out.
To Oil Change Question
