Turn Signal Problem 1991
1991 Coupe.
The right turn signal arrow is on constantly...on the dashboard. Brake lights work. Left turn signal works front and back. Right turn signal does not work. Flashers work front and back but right front turn signal light is half as bright as the left side...this is after replacing the bulb on the right side 2 times. Wassup with this???
Received 1,674 Likes
Has the RF bulb socket ever been replaced?
The parking lamp and turn signal wiring may be reversed at the socket.
