Oil Catch Can .... It really works..
During my installation of my CAI on my C5, I notices oil in my intake manifold area. So I purchased a "Oil Catch Can" on "fleabay" and installed that. Check it with normal driving in 4 weeks, 1/4 of a cup. That's oil that would be in my intake manifold..
Received 19,225 Likes
'20-'21-'22-'23-'24
Yes, they do work - nice to keep that oil out of the intake.
pifo1964 (05-03-2018)
Location: ALL governments are legalized mobsters, so doesn't matter where I live :(
From what I've read it just gets the intake messy (obviously) and anything that makes it into the engine just burns away, but doesn't do any kind of damage...or so I'm told.
-Alex
Leo001 (10-01-2021)
Received 3,036 Likes
Does the catch can drain back to the oil pan or are you emptying it every so often?
Don't get me wrong, I like the idea, just didn't think it was as much a needed requirement.
here's the gist off it, from elite engineering usa website i hope he doesnt mind.:
Purpose of your Stock PCV System:
The PCV (Positive Crankcase Ventilation) system is designed to regulate and
remove fumes from the engine crankcase, and to alleviate crankcase pressure which
could cause oil leaks or seal damage. The PCV system routes crankcase fumes into
the intake manifold where they can be burned to eliminate harmful emissions into
the atmosphere. The PCV valve controls the amount of crankcase flow volume
depending on the engine's load. With large throttle openings (high engine loads),
the more blow-by gases are produced, and the more the PCV system flows oil vapor
in to the intake manifold. The PCV valve also functions as a check valve to prevent
intake manifold flow from reversing back into the crankcase when there is a
backfire, or during periods of high manifold pressure (boost) during forced induction
by turbocharger or supercharger.
Negative Effects of your Stock PCV System:
Many Corvette, Camaro, Firebird and GTO owners with LSX engines can
testify to the amount of oil residue that can accumulate inside the intake manifold,
throttle body, intake track and even the air filter during aggressive driving
conditions.
There are various negative effects when excess oil vapor contaminates the intake
system from the stock PCV system - such as:
*Throttle body and/or MAFS (Mass Air Flow Sensor) malfunction or failure.
*Air filter, intercooler (if equipped) and intake ducting contamination if oil pools and run back out the intake system after engine shutdown.
*Reduced octane of the air/fuel mixture, which can cause detonation and the ECM (Engine Control Module) to retard timing, thereby reducing engine power.
*Excessive carbon build-up on valves, piston crowns, combustion chambers and spark plugs. This also increases the chance of detonation and power loss.
*Increased emissions & possible contamination of catalytic converters and oxygen sensors.
Bottom line: Excessive amounts of oil vapor in the intake manifold is detrimental to
your engine!
conditions.
your engine!
Thanks Steve-O, I was about to explain but you did a great write up.. Bottom line guys, it just traps the oil going into the intake, you have to drain the unit at least once a month, and if you push your vette, it builds up pretty fast. Now on prices, you can spend up to $19 to $149, or even make one up yourself. Go to "FleaBay" and type in "Oil Catch Can for Corvette", and pick your posion.. In my own words, you don't need to spend $100 on them, they are simple in design and as long as the oil has room to gather and drop to the bottom, it will be better than the stock setup.
Note: For you California folks, even they are better than stock, it is illegal to install, so you will have to return to stock every 2 years for the smog test. I found a place that understands what it is and over looks it.. Good luck
Only in California !!
Andy46, we have the most stupid laws in California, enough to make me think when I do retire, to leave it. I just may, but we will see. You are correct, it is a big improvement over stock, but what I found is that if the manufacturer of the Oil Catch Can has CARB research test it (at a cost) and it proves better, they would allow it and a CARB approved stamp can be applied. No one wants to spend the money to have it tested, commen sense says it's better, but no test, not pass, and that's how it works. CARB wants the money is what it boils down to. Same with some CAI, even the dual air filter setup looks like a CARB one, (that is why some cost $289 and other that look just like it cost $39), it didn't go through the testing, thus, illegal... BS if you ask me. But no one does, so there.
Sad fact is eventually everyone else ends up doing what Cali does, regardless if it makes sense or not.
But getting off topic here, I like the catch can idea and am going to look into one for my car.
Cheers
