I'm real happy with the x pipe..........
i actually had the impression that the siamesed or joined style was just a cheap imitation of a real x pipe. but it all makes sense. joined style, the 2 sides mingle and flow on through. the x style has a collision of the 2 sides, then it's a fight for who goes down which side.
does that sound about right?
Am I getting closer??
In my uneducated opinion I would say yes, plus siamesed one just looks like it is less restrictive to me. Before I ever started researching this stuff I knew if I was going to get an x-pipe I didnt want to buy anything but the siamese style just because it appeared to flow better from what I knew.
now someone who makes the true x type is going to come up with some kind of engineering flow printout to show why we're wrong.
Received 2,675 Likes
2018 C5 of Year Finalist
Wow! Great info on this thread. I am planning to install a thermal tunnel plate and was considering adding a Corsa X-Pipe while I have the exhaust dropped. I already have the Corsa Pro Indy exhaust and love it. However, I was hoping for some performance and torque improvements. This is the Corsa X-Pipe I'm considering...
Rock and Roll,
I installed a joint X-Pipe on my Mid America Quadrapower exhaust this past Tuesday at Mid America. It made the exhaust note a little more mellow, not so throatie. Also, in 6th on the highway, the sound level was cut in half. I really like the setup...sounds awesome! Still has that "Vette" roar...yeah!
Mike
Mike
Look at how each are described in the posts regarding airflow/hp and construction and you'll see more positive direction toward the "joined" X.
A full 16ga steel cat-back system sent out for internal and external ceramic coating will not be much cheaper than a stainless steel system. Besides, they usually rust from the inside out. Moisture inside the exhaust system eats them away, if the tack-welded internal baffles don't break first. After 3 cars with Flowrusters, I switched to stainless steel straight-through design exhausts and never looked back. That's cool that you are happy with yours, though.
A few months ago I had my shorty headers ceramic coated inside and out at Sandersons in South San Francisco for $80. Mufflers wouldn't cost much more than that.
And Flowmaster doesn't "tack weld" ANYTHING that goes out the door. I did see some of the old mufflers that weren't aluminized steel that had rusted out badly, but the aluminized ones are many times more durable. If you make a lot of short trips and the exhaust system never gets a chance to heat up enough to burn off condensation, then it will shorten the life of the mufflers.
