s/c kit for c5?
Old Sep 5, 2011 | 06:59 PM
JMG2's Avatar
JMG2
Moderator
Default s/c kit for c5?
Drove a c6 rental (hertz) last week... really amazed how much power on tap that thing has, made me want to go back and add a few more ponies to my ride....
Currentlly have an intake, flash, headers, z06 exhaust, and 4.10 gears.
Was thinking if there was a super charger kit available, I may add that on... I'm sure tons of people have done it, whats the best route?
Alternatively, any other thoughts on adding power? s/c seems the easiest route... only other avenues I can think of are heads/cam/new motor :-)
Old Sep 5, 2011 | 07:03 PM
pluslt's Avatar
pluslt
Here you go. Give these guys a call.
http://www.eastcoastsupercharging.com/
Old Sep 5, 2011 | 07:04 PM
rootpooty's Avatar
rootpooty
Relatively simple as far as supercharger kits. Contact A&A or ECS. If your really going to do a supercharger then your gonna want to ditch those 4.10's
Old Sep 5, 2011 | 07:18 PM
JMG2's Avatar
JMG2
Moderator
:-) I love the 4.10s though !!!
Old Sep 5, 2011 | 07:31 PM
rootpooty's Avatar
rootpooty
Im a bit confused though. Your car should be faster than a stock ls3 with the current mods you have
Old Sep 5, 2011 | 07:39 PM
nj02vette's Avatar
nj02vette
From: Marlton. Increasing performance one speeding ticket at a time! NJ
Yes,
There are many kits available. You should check out the C5-Forced Induction section of the forums. Lots of info there.
There a a few diferent options.
Centrifugal type superchargers fit in the engine bay, but are a bit more difficult to install. They also generally produce the most power.
The two biggest manufacturers of kits are ECS and A&A.
There are also roots types, that replace the intake manifold. These are easier to install, but the extra height requires a new hood with clearance. They generally make a little more torque down low but not as much power.
Old Sep 5, 2011 | 07:43 PM
TheRadioFlyer's Avatar
TheRadioFlyer
Supporting Vendor
I'm selling my Vortech V-2Si Centri kit. It added over 100hp to my tired old 97 motor.
http://forums.corvetteforum.com/c5-p...arger-kit.html
With the correct tune you could easily gain 150+
Old Sep 5, 2011 | 08:30 PM
Wkeil99hardtopred's Avatar
Wkeil99hardtopred
Mechanical h/p, headers cam displacement will last you longer i believe.
Old Sep 5, 2011 | 08:48 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
ouch, you have to spend additional money to swap back to 3.45
This is why its best to know what your plans are for the car before doing any mods.
Old Sep 5, 2011 | 09:01 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
A&A or ECS you can not go wrong
Old Sep 5, 2011 | 09:08 PM
There are a number of superchargers available for the C5 - Magnuson, Procharger, Vortex, A&A, etc. All will get you a lot of extra HP. You could also add a head/cam and get a nice gain.
Old Sep 5, 2011 | 10:39 PM
JMG2's Avatar
JMG2
Moderator
I put the 4.10s in over 5 years ago, and had no idea I was going to get the FI bug. But thanks for the advice.
Someone mind explaining why I *need* to swap back the 3.45s?
Old Sep 5, 2011 | 10:46 PM
1999corvettels1's Avatar
1999corvettels1
From what I have read, you will have no traction with 4.10 and a supercharger!
Old Sep 5, 2011 | 10:52 PM
rootpooty's Avatar
rootpooty
You should have no problem finding someone to trade your 4.10's for stock 342's. I would definitely be on the lookout for a zo6 diff with 342's
Old Sep 5, 2011 | 10:55 PM
JMG2's Avatar
JMG2
Moderator
Yes, but it is necessary to swap?
I just spent over $1k last year on rebuilding the rearend (the "performance" shop that did it used crappy parts and the rearend died).
I'll start lurking in the FI forums... nothing pressing right now, just exploring.
Old Sep 5, 2011 | 11:04 PM
rootpooty's Avatar
rootpooty
Its kinda necessary to swap. With 500hp you will have zero traction.
Old Sep 5, 2011 | 11:09 PM
rootpooty's Avatar
rootpooty
Im a N/A guy so with your car already having the gears I would jump on a set of heads and a nice cam
To s/c kit for c5?
Old Sep 5, 2011 | 11:12 PM
rootpooty's Avatar
rootpooty
Here check this out http://forums.corvetteforum.com/c5-p...ferential.html
Old Sep 6, 2011 | 07:29 AM
had2have-it's Avatar
had2have-it
A supercharger is gonna give you more power, no doubt. You're gonna have to do an up graded clutch, definetely 3:42 rear, and it will become alot more fuel quality sensitive, might need a meth injection kit. Might consider a mild cam and head package, you'll get a good improvement. With the mods you already have what did you get for rwhp? And you mention flash tune, you might want to also consider a dyno tune by a competent tech.
Old Sep 6, 2011 | 08:12 AM
nj02vette's Avatar
nj02vette
Gears change the rear end tire to engine RPM ratio. The higher the numerical gear, the slower the rear tires spin. But this reduction in RPM also comes at the increase of rear end torque. So going from 3.42 to 4.10 slows the tires by about 20%, but also increases torque 20%.
That's why gears make your car "feel" faster and helps light the tires up. More torque. Now you bump your torque up even higher with the Supercharger, and you've got an aweful lot of torque.
4.10's are common with cars that go head/cam, since the larger cam specs make the low end pretty weak. The gears somewhat make up for that. I'd suggest going with a centrifugal type setup if you want to keep the gears. At low RPM/low gear, you won't be in boost and it will drive virtually stock. But hold on when you mash the pedal.
