Need some Advice/Help....Coilover damage..Pic Heavy
#41
just went out and took a pic of mine....old or new? I bought them about a year ago from a forum vendor.
#42
Im not I've ever seen a side by side for old and new designs. I did Private message both Anthony and Louis at LG last night. Still waiting for a response. Hopefully I can get my car backup and going soon
#43
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
https://www.lgmotorsports.com/contact-us
They don't always check PM's quick, but can be reached by phone.
They'll get you fixed up.
#44
Yea I sent Anthony an email at LG......Im sure they'll get the guys back up and running ASAP...Id just like to know that mine are good before heading out of town in the car this weekend
#45
Anthony got back to me on Wed. He would like me to send the broken coilover back to LG to inspect. Supposedly my set is apart of the updated designs. I probably adjusted the fronts 3-4 times within the first 2 months of installing the set. Carefully following proper adjustment instructions in the process of setting my desired ride height
Hopefully this is an isolated case.
Mike
Mike
#46
Hmmmm, that doesnt sound promising. I was very careful to adjust mine per the instructions as well. How low did you have your car?
#47
Received 19,233 Likes
'20-'21-'22-'23-'24
Good luck getting all these coilover problems resolved. Sounds like LG is taking the right steps.
#49
#50
Anthony @ LG motorsports mentioned that they are in the process of moving shop to a new location. I'm assuming this issue will be somewhat delayed but justified.
I will keep everyone posted on the situation as we go along. I called and left a message with Bobby letting him know I am more than glad to chat about the short details of what happened.
Again this set I have is said to be the current design. It will be quite interesting to know exactly what went wrong once its carefully looked into.
thanks
Mike
thanks
Mike
#51
Mike, does LG currently have your failed coil over? Im very curious to see what the outcome is. Mine are also set at just slightly lower than factory Z06 ride height. The idea that these could fail at any time is not a pleasant one.
#52
#53
so has anyone gotten anything definitive back from LG?? I emailed them last week and still haven't heard anything back
#54
Toque
#55
Gotchya....out of curiosity, have you had any problems with your coil overs? I know you've had them for a while now, and run a pretty low ride height
#56
I mentioned the issue to Anthony years ago when I installed mine in my garage. I found out that turning the shock into the lower cup would turn the top bolt at the same time. My upper shock assembly came loose and separated on me in my garage when I was trying to shorten my shock length. Surprised me for sure. I'm may have been the first one to mention this to Anthony, which cause them to redesign... I'm not sure though. The re-design stopped the upper bolt from turning when your shortening the shock length.
I later made sure mine were screwed ALL the way up into the upper housing when I completed my install.
Toque
#58
Roland
#60
Glad they got you hooked up with a new set Now I really wish they'd respond to the email I sent, or in some way address those of us who have them and would like to know why they keep failing
