[Z06] New wheels/tires- lowering question
Wanted to show off my new wheels/tires & brakes. Plus I had a question about lowering. With my old wheels/tires, the wheel well gap looked good, but with the new setup it looks like I'm 4 wheeling. Looking at the pictures, how much lower can I go before the suspension travel makes the tires hit the fenders? I thought the car had been previously lowered, but now I doubt it.
Rear wheel
Front wheel
Rear wheel
Front wheel
Lowered on what? Stock bolts? Cut stock bolts? Aftermarket bolts? Coil overs. If you're running stock length shocks, you're into the bumpstops before the tires hit the body IMO.
Received 1,679 Likes
Nice..
Why would you buy new wheels, and put a 325 on a 10.5? Just because it's squeezed on that skinny wheel, doesn't mean it makes a full contact patch! Want big rubber that can work? Put em on proper width/offset wheels. I don't get it...but it's your car.
Style wise they look nice, but...
Wheels & tires look awesome in my opinion.... I think the rear tires fit the wheels perfect.... Nittos tend to run narrow anyway....
I would lower it about 1" all around and call it good. Make sure to get an alignment right after you lower it....
Nonetheless nice choice of wheels and good looking car!
The tire isnt as wide as my last set of 325/30's and when I mounted it on the rim, I did not have to compress the side wall that much to get it to seat. When looking at the contact patch area of the tire, it visually appears to be clost the the width of the rim, maybe 1/2 over all wider (1/4in either side) The Nitto's run narrower than most other tires.
My 305 Nitto DR’s are even a little pinched on a 10.5’’ wheel and the sidewall is even a little bubbled. I can only imagine a Nitto 325. Either way as long as your happy that’s all that matters.
I'm also running the Nitto Invos @ 325-30/19, but my rear wheels are 11" wide, which, BTW, fit fine. As far as your lowering question, the lowest you can go on the stock bolts will not create any problems, other than a slightly rougher ride. It probably can go a bit more, but it looks OK to me as is.
