[Z06] Lifespan of a clutch
What's the lifespan of a z06 clutch with an avg corvette daily driver?
Corvette daily driver = daily drives his car with that occasional spirited driving and 1/4track once or twice a year with a clutch dump lol... Aka ME!
I'm curious he long it'll last. I k ow its an expensive thing to do... Probably
Like 1000 for labor? I have no idea...
It's not slipping or anything, I just wonder when it might, so I can start saving for it lol
I went 78k miles on my stock clutch with the usual bolt ons and same driving as you. Still had quite a bit of life left too, only problem was one of the forks got stuck and the clutch would no longer disengage or engage. As long as you use the clutch properly you should be able to get a lot of life out of it.
I'm having virtually the exact same situation. I've got a perfectly working clutch with no slipping whatsoever, still works smoothly and chirps the tires, too. I'm at 99,700 miles. My slave has just started leaking. I have to add a little fluid occasionally at this point. I can't see going in there to just change the slave and not change the clutch with the miles I have even though the clutch doesn't need replacing. It also isn't a good time of the year financially to have to do this. How long did you drive your car from the time you noticed the leaking until you repaired it? My car is still driving great. Really ticks me off that there is so much work to replace one simple part.
Got my car at 42K miles (Not sure if clutch was ever replaced or not). Its still going strong at 73K miles. I change my fluid every 3 months/after hard runs.
My old car had 125,000mi with the stock clutch when I sold it, still running strong too. It was a daily driver and saw the 1/8th mile track a few times.
Bringing back an old thread, but I think I will replace it this year....
now my question is, what is the usual labor this? I'm looking at a LS7 clutch kit, which should handle my bolt on Z06... with no problems.
is there anything else that you can reccomend? I really don't want to go over $1,000 for everything including labor.
any idea on labor?
any idea on labor?
any idea on labor?
any idea on labor?
