long tube header??
Old Dec 21, 2011 | 07:26 PM
nosgsxr's Avatar
nosgsxr
Default long tube header??
ok i been looking around and cant find anything on here about the install of the headers... i was wanting to know how hard it is to install them..sounds like its the way to go for the start of the mods...i have a K & N CAI and gonna get a dyno tune but was wanting to try the headers... i have a shop with a 2 post lift..... any links thanks all
Old Dec 21, 2011 | 07:31 PM
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
Grab yourself some lg streets. They slide right in.
http://shop.jwmotoring.com/product.s...&categoryId=12
And this is a good DIY. Installation is simple on the c5
http://www.ls1howto.com/index.php?article=29
Old Dec 21, 2011 | 07:49 PM
nosgsxr's Avatar
nosgsxr
mine is an 03 ZO6 is it the same?? thanks for the link im gonna bookmark it,,
Old Dec 21, 2011 | 07:57 PM
sean.b's Avatar
sean.b
pretty much the same. if you have a lift, it should be a LOT easier than doing it on the ground, which even then wasnt too too bad. just tedious. it's just an exhaust after all
Old Dec 21, 2011 | 08:02 PM
Gray Ghost GS's Avatar
Gray Ghost GS
"AlohaC5" Senior Member
Google:
"how to install corvette c5 headers"
You will see a .pdf document from LG Motorsports on a "How To"......
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
Here's another: http://97vette.com/howto/headers/index.html
Old Dec 21, 2011 | 08:15 PM
Mike98SilVert
Different instructions form different manufacturers. Some more links:
http://www.cajundude.com/longtubes.htm
http://www.slponline.com/inst/30094.pdf
http://www.corvettefever.com/techart...all/index.html
http://www.melroseheaders.com/install_instructions.php
Old Dec 21, 2011 | 08:39 PM
nosgsxr's Avatar
nosgsxr
WOW!! thanks for the replys...now i just need to find me some headers..........
Old Dec 21, 2011 | 09:00 PM
m6 c5's Avatar
m6 c5
Its pretty much the same for all C5's and I can say for sure that the Lg pros are pretty straight forward. Its a fair amount of work but its not difficult.
Old Dec 21, 2011 | 10:38 PM
JW Motorsports
Banned Scam/Spammer
Yes same thing.
One of my z06 customers recently installed the streets from us
http://forums.corvetteforum.com/1579488283-post7.html
Old Dec 21, 2011 | 11:10 PM
tkdenton's Avatar
tkdenton
"Its a fair amount of work but it's not difficult" is a true statement if you have some mechanical background. Do Not Let anyone fool you - if you don't have any mechanical experience, you might want to pay for the install . One other thought - I installed my LT's with the car on jack stands. If you have a lift available jump on it. It will make the install so much easier. One more other thought - buy XS Power LT's.
Old Dec 21, 2011 | 11:15 PM
sean.b's Avatar
sean.b
i dunno. i'm a computer geek with limited mechanical experience, and it was just tedious. unless you have a fried short term memory/ADD/have ever stabbed yourself with a spoon, i'd say it's really no big deal. the walk-throughs online make it too easy.
Old Dec 22, 2011 | 02:04 AM
6 Shooter's Avatar
6 Shooter
Default LG's
Old Dec 22, 2011 | 02:06 AM
sean.b's Avatar
sean.b
uh, wut? was that baseline after the header install as well? cus if those only gained 6hp i think im gonna go cut myself.
Old Dec 22, 2011 | 02:11 AM
6 Shooter's Avatar
6 Shooter
They missed up the baseline, I gained 30 HP...
Old Dec 22, 2011 | 09:30 AM
JW Motorsports
Banned Scam/Spammer
Impressive gains for sure
Old Dec 22, 2011 | 12:25 PM
sean.b's Avatar
sean.b
what else was done? cus 374 sounds high'ish for just headers on a 241 heads ls1?
To long tube header??
Old Dec 22, 2011 | 12:42 PM
6 Shooter's Avatar
6 Shooter
Default She's touting a GMPP LS6!
Old Dec 22, 2011 | 12:51 PM
LoneStarLizzard's Avatar
LoneStarLizzard
I agee. I had LG do the install (Street Pro's) and do a tune. Here are my results, with an A4 automatic with 3,000 miles on the clock (all at the rear wheels, of course):
Baseline: 305 hp 319 lb/ft torque
After install: 333 hp 347 lb/ft torque
A few months later, when I had 8,000 miles on the clock, I had Quality Morotsports install AFR 210 heads and a mild cam. After that install my results were:
After install: 400 hp 391 lb/ft torque
All results will be higher with a 6-speed, but you get the idea.
Old Dec 22, 2011 | 07:58 PM
m6 c5's Avatar
m6 c5
Maybe he has a freak engine...
