Hey Vendors...how about tooling up for this part?!
Location: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
Gear indicator in the PRNDL...a simple casting of the plastic part would work, and last a lot longer...could be zinc, or brass, like the headlight gear. Or, nylon 6:6 in plastic...come on, I know you can do it, and do it right...show GM how it should have been made.
Received 19,293 Likes
'20-'21-'22-'23-'24
Would be nice if parts like that were available for us A4 owners.
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
Yes, and while they're at it, they need to come up with a HUD dimmer control ****. GM does not make it any more either. You have to buy the whole darn control to get this ****.
Received 1,675 Likes
An upgrade there would be great!
Yeah I like that idea too - hard part to get and find!
I would be in for one!
Thanks,Matt
Thanks,Matt
I did make a shift indicator from brass, 1998 a4
My shift indicator broke on my 1998 a4, they are not available. I am a jeweler and I took it apart, which is easy and made a mold of it. I cast it in bronze/brass and painted it with bright yellow. You can have this done if there is a jeweler in your area that really makes jewelry, most just sell other peoples products. It is labor intense but it will never break again!
Broke my little plastic indicator a few years ago putting on a shift boot. The only alternative is buying a $200+ shifter assembly.
Put me on the list.
Put me on the list.
Its not the only alternative, I could make you one. Email me an address and I will send two for testing. I also have a problem I am afraid to bring up on here, it been brought up so many times but it still is not fixed.
will you make me one and send to Eugene Howard 25734 Glen Loch Dr. The Woodlands Texas 77380 call 832-264-6920.
Do you need a replacement gear shift indicator?
I have desgined and produced a replacement gear shift indicator for an automatic C5 Corvette that I currently have installed.
I also have a limited number of samples that I am giving away. However, I will not be liable for any loss or damage caused by installing it.
All I as is that you let me know if it works for you.
If you would like one then please PM me.
How did you make that?
I have already manufactured a shift indicator tab out of .020 stainless sheet and a 0.250 roll pin and epoxy with reflective tape for a red indicator. works good and will last forever. thank you for the offer. I made 2 and have 1 spare. Eugene Howard
