Bi-Xenon HID retrofit in ACA style housings
When I bought my car, it came with a set of 6k HIDs installed in the stock housings, and they were just throwing around light everywhere but where I needed it, so I decided to do a good retrofit. I like the pop ups, so I started to search for clear lens housings to use, but it looks like the ACA style ones are all that is available. The only downside I have heard about them was aim on the high beams...which didn't bother me at all since my goal was to install a set of bi-xenons anyways!
I couldn't really find where anyone retrofitted actual HID projectors in these housings to see what fits and what doesn't, so I just took a stab in the dark. I ordered a set of FX-R 1.1 projectors, 4300K Phillips D2S bulbs, and went to town!
For anyone else looking to do this, here is a shot of how the ACAs look when they come in:
Here is what we have to work with for mounting holes when the stock projector is removed.
It's a really tight fit, but here is the projector squeezed into the stock projector hole. The solenoid for the high beam shield rests on the bottom of the hole, but it doesn't interfere with anything.
Now we have to take the FX-R projector apart to drill the mounting holes in the front housing. Match up the 4 holes to the 4 points on the housing, and drill them out.
Then find 4 screws long enough to go through the housing and mount secure into the headlight housing and screw them in.
All done! Doesn't look any different from this angle.
Installing these into the headlight brackets still requires a bit of trimming, but everything fits in nicely.
One side done:
Both sides:
Output shots will have to wait, all I had for pictures was my cell phone. I'll grab the SLR tomorrow if it's not snowing out. But the beam pattern is wide with even spread of light and a very sharp blue/purple cut-off. Much better than before.
Only thing I have to do now is figure out how I can run both the high and low beams at the same time. I saw one write up where someone wired in a relay to do this...anyone know if I have to have a relay for each headlight?
One side done:
Both sides:
Plentyfast (05-16-2017)
Location: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
One side done:
Both sides:
One side done:
Both sides:
Mr.Bill
I've been waiting for someone to do a retrofit on a set of headlights. Tried looking for a set of plain oem style headlights with a clear lens to do this exact thing, but can't seem to find anything. Looks like you came to the same conclusion and settled for a set of ACA's to modify.
I'm def interested in how everything turns out. So far the project looks great man, nice job.
Received 1,675 Likes
I really like those.
Night Owl for life
Received 3,247 Likes
Good job.
Night Owl for life
Thanks guys, Bill sent me the write up on the highs and lows and I'll stop by Radio Shack after work and build the harness. The ACA lights came with a set of full length harnesses, but I don't want to re-run all the headlight wiring just for that.
NVUSGT - That exactly what I was looking for, but it looks like nobody makes just a clear lens stock housing. I figured if the circle look ever bothered me, I could take the clear lens off of the ACA housing and put it on the stock lights and retrofit into that. But the upside about flip-up lights is that they are hidden until I need them at night, so I don't think I'll even bother. The look is growing on me anyways.
Wow ! Very cool !
Yea I agree... the high beams on the ACA's do suck a lot. I can't wait to see how this turns out.
Thanks !
Toque
Thanks !
Toque
Oldtimer
The finished job looks great!
I'm curious/confused, however. It didn't look like you did a full replacement of the entire light housing? How much of the stock equipment did you use? Can you give me a ballpark idea of how much the whole deal cost??
Thanks!!
Thanks!!
I've got maybe $600 in the set-up when all is said and done. You could probably go cheaper if you didn't use OEM bulbs.
Here are a couple beam pics. Guess I needed the tripod...they looked better on the small screen. But the view from behind the steering wheel is wonderful! I can enjoy driving at night again!
Low beams
High beams
No glare for oncoming traffic:
Crappy shot at the colorband.
Low beams
High beams
This looks great! Nice job! I am tempted to do this, too!
Did you get the new headlight assemblies on Ebay? Are the lenses glass or plastic? Was it hard to get the lenses off the back? How did you get the lenses off the back? Thanks in advance!
Received 19,296 Likes
'20-'21-'22-'23-'24
Any way you can post up what Mr. Bill sent you? Or for Mr. Bill, can you post it up here?
Those look great.
Those look great.
Night Owl for life
Wow thats a great looking cutoff.
