May 2012 C5 Aftermarket Specials at GMPARTSHOUSE.com
Premium Supporting Vendor
Hello everyone,
As many of you are well aware GMPARTSHOUSE.com is expanding to not only be your main source for everything GM but now also we carry many aftermarket lines for your shopping convience. With that said I present our aftermarket C5 specials list
Performance
Skip Shift Eliminator
Price 22.99
Click here to order
Decide for yourself what gear you want to be in! Dump that annoying first-to-fourth "skip-shift" incorporated in your manual 6-speed Camaro, Firebird, Corvette, GTO, GXP and Dodge Challenger with SLP's Skip-Shift Eliminator. This PLUG IN piece requires no additional modifications to your vehicle. With it in place, you take complete control over gear selection. Isn't that why you got a manual 6-speed? Plug in installation and is shipped complete including easy installation instructions. Note: Not legal for use on pollution controlled motor vehicles. For Off-Road Use Only.
Cooling System
Thermostat, 160º LS1 1997-03 Corvette
Price 53.95 Click here to order
Racers know that a cooler running engine is a better performing engine. Reducing the temperature at which an engine runs will make more power through better thermal and volumetric efficiency. SLP offers this 160º thermostat for all LS1 Camaro/Firebirds, LS1/LS6 Corvettes, and Full Size Trucks equipped with 4.8, 5.3L, and 6.0L engines. This new thermostat replaces the factory 195º unit, allowing coolant to circulate at lower engine temperatures, keeping the engine cooler. Not legal for use on pollution controlled vehicles.
Thermostat, 160º 2004-08 LS1/LS6
Price 22.99 Click here to order
SLP offers this 160º thermostat for all LS1/LS2/LS3/LS6/LS7 2004-08 Corvettes/2005-06 GTO/2004-06 (2007 Classic) Full Size Trucks/SUV's equipped with 4.8/5.3/6.0L engines along with 2006 Trailblazer SS and 2008-09 ½ Pontiac G8. These low-temp thermostats dramatically reduce operating temperatures, while increasing thermal efficiency and your engine's performance in the process. Racers know that a cooler running engine is a better performing engine. This new thermostat replaces the factory unit, allowing coolant to circulate at lower engine temperatures, keeping the engine cooler. NOTE: Not legal for use on pollution controlled vehicles.
Venair Silicone Coolant Hose Sets at the unbelieveable price of 279.95 for the complete 8 piece set!
To order you can simply click here
VenAir Silicone Hose Kit - Coolant: Venair Silicone Hoses are hand crafted using the highest quality VMQ silicone. Every hose is subject to strict quality controls. Advantages of Silicone Hoses: Venair Silicone hoses can withstand far higher & lower temperatures than the standard EPDM rubber hoses commonly found in OEM engines. Silicone hoses are the preferred choice for motorsports teams and enthusiasts alike because of their increased durability and performance and their amazing high gloss finish that is available in black, red, yellow and blue.
This hose kit is ideal for upgrading a cars engine bay appearance and is used by serious motor sport users who demand the best performance upgrade.
Engine
Harmonic Balancer/Underdrive Pulley, 1997-11 LS1/LS6/LS2/LS3 Corvette
Price 197.95 Click here to order
SLP's 25% underdrive balancer for the LS1/LS6/LS2/LS3 Corvette and 2008-09 L76 Pontiac G8 and 2009 GXP incorporates a number of high-quality features you won't find on any other aftermarket unit. Chief among them are a pair of extra-tall belt-retention walls that eliminate the belt-slippage issues common to other balancers. Gains of up to 10 horsepower can be expected. Other unique design strengths include 100% steel construction (other brands use steel and aluminum), integral timing marks, and built-in puller-mounting threads. Includes a new balancer bolt and detailed installation instructions.
NOTE: Balancer requires two new belts not included.
C5/C6 Corvette
Main Belt: Gates 6PK1900 or Equivalent
Accessory Belt: Gates 4PK1040 or Equivalent
Pontiac G8/GXP
Main Belt: 6PK1880 or Equivalent
Accessory Belt: 4PK1080 or Equivalent
FEATURES:
Extra-tall belt-retention "walls"-no more thrown belts!
No aftermarket tensioner required
Lighter than the stock balancer
Integral timing marks and puller-mounting threads
Keyed for high-rpm or supercharged applications
Does not cause false knock retard or erratic power-curve dips
SFI Approved
NGK TR55 PlugsPrice 2.36 ea Click here to order
Economical performance and improved ignitability over standard NGK Spark Plugs original equipment manufacturer and racer approved.
- Lowers ignition system voltage requirements
- Greater ignitability and performance over conventional spark plugs
- Trivalent Metal Plating has superior anti-corrosion and anti-seizing properties
- Increased fuel economy and lower emissions
- Highly durable against electrical and chemical wear
- Good performance spark plug
Exhaust
Exhaust System, 1997-04 C5 Corvette
Price 611.95 Click here to order
STYLE SLP Performance Parts, the aftermarket’s premier manufacturer of performance exhaust components, is pleased to offer the all-new C5 PowerFlo™ cat-back system for 1997-2004 Corvettes. The centerpiece of the C5 PowerFlo™ is its industry-exclusive cast aluminum tip, which was styled by a member of GM’s C5 design team and features a unique shape that conforms to the vehicle’s rear-fascia opening. PERFORMANCE AND SOUND The C5 PowerFlo™ is equipped with a pair of application-specific mufflers that were specially designed to provide a rich, muscular exhaust tone while minimizing interior resonance. Improvements of up to 10 horsepower are possible, thanks to a drastic reduction in backpressure over the restrictive factory system. QUALITY AND VALUE This system is hand-crafted from show-quality 304 stainless steel and covered by our limited lifetime warranty. And at a suggested retail price of only $849.95, it’s significantly more affordable than most competitive stainless steel offerings.
Price 719.95 Click here to order
Give your 1997-2004 C5 Corvette a bark to match its bite with SLP's Loud Mouth™ exhaust system. Constructed from mandrel-bent 304 stainless steel, this bolt-on system offers up to a 15 horsepower gain and a 20-lb. weight savings over stock. It features 2.5" over-axle pipes and 2.25" tail pipes with 4" polished exhaust tips. Detailed instructions, a limited lifetime warranty, and all hardware necessary for installation are included. Loud Mouth™ cat-back exhaust system for C5 Corvette features: Hand-crafted from 304 stainless Up to a 15 horsepower gain Polished 4" dual wall split round tips Easy bolt-on installation Limited Lifetime Warranty
Header Package, 1-3/4
Price 1299.95 Click here to order
NOTE: SLP Long Tube Header & Aftermarket Catalyst Disclaimer THE USE OF LONG TUBE HEADERS WITH AFTERMARKET CATS, POWERFLO-X CROSSOVER PIPES WITH AFTERMARKET CATS OR AFTERMARKET CATS ARE ILLEGAL FOR INSTALLATION AND USE ON EMISSION-LEGAL VEHICLES WHEN OPERATED ON PUBLIC STREETS OR HIGHWAYS. THEY CAN ONLY BE LEGALLY USED WHILE PARTICIPATING IN SANCTIONED MOTORSPORTS RACING EVENTS. FOR COMPLETE DETAILS CLICK ON THIS LINK: SLP DISCLAIMER Install Time: 6 SLP's C5 Corvette Long-Tube Header Packages feature 1-3/4" primary tubes flowing into two 3.0" high-flow venture-style collectors. The headers are mandrel bent 409 stainless steel and ceramic coated to keep heat in, exhaust velocity up, and under-hood temperatures down, while the rest of the system is made from high-quality 304 stainless steel. Also included in the package are a pair of 3" high-flow catalytic converters, which flow into a 3" integrated PowerFlo-X Crossover assembly. They're fully compatible with all stock emissions-control equipment and use OEM flanges for a perfect fit and proper bolt retention. All necessary installation hardware are included. Backed by our Lifetime Warranty. FEATURES: +20 HP and +18 Ft-Lbs at the REAR WHEELS over STOCK 1-3/4"Ceramic Coated 409 SS Mandrel Bent Long Tube Headers New High Flow Collectors for More HP and Torque in the Mid to Upper RPM Range Metallic Substrate 200 cell/inch High Flow Cats Included New 3" High Flow X- Pipe Designed for Unrestricted Flow Will Bolt to Factory Cat-Back or SLP Cat-Back No wiring needed for installation/Drop in design for easy installation. All Clamps/Hardware/Extensions and Instructions are included to complete the installation.
Exterior
Spoiler, 1997-04 C5 Corvette Rear Lip (unpainted)
Price 224.95 Click here to order
SLP's one piece, tape-on rear spoiler provides a subtle but elegant upgrade to the rear of your car, enhancing the already great appearance of your C5. Unlike rigid fiberglass aftermarket spoilers, ours is manufactured from OEM-quality composite material, the same flexible material that GM uses to manufacture front and rear C5 fascias. Each spoiler comes ready for prep and paint with OEM-quality double sided tape for an easy, tape-on installation (no drilling required). All necessary components, 3M tape and installation instructions are included.
Performance
Price 22.99
Click here to order
Cooling System
Engine
C5/C6 Corvette
Pontiac G8/GXP
FEATURES:
SFI Approved
Exhaust
Exterior
__________________
Patrick Trageser
CULTRAG Performance
Your one stop source featuring the true experts for all GM Parts and Accessories, Lloyd mats, SLP Performance and Hawk Brake pads!
Order Your GM Parts at www.CULTRAGfactoryparts.com
patrick@cultragperformance.com
1-484-334-8833
CULTRAG Performance
1-484-334-8833
dont forget to check out our OEM parts specials at http://forums.corvetteforum.com/c5-p...house-com.html
Just got my brake ducts and screens and wanted to thank you guys for great service and follow through after placing my order. Parts are great and prices even better. I'll be placing more orders soon.
Thanks again, Zig.
Thanks again, Zig.
Hello everyone
I would just like to introduce myself, my name is Justin and I am the newest addition to the team at GMPARTSHOUSE. I look forward to helping you all. Please feel free to give me a call or shoot me an email.
Thank you and have an awesome day!
