Removed my Hood Liner for a "cleaner" look.
Guys:
So I got the itch to remove my hood liner. I never much liked the look of it anyways. Seems to have cleaned up the look under my hood. I have seen other people do it and it looks like more of a "cleaner" look to me.
Its got a little bit of factory marking on it, but for the most part its really clean. Its a dull silver color. No clear coat on it for sure.
I like it !
Toque
I like it !
Toque
Let's see what the heat and a/c compressor spray do to the paint on the top of the hood after a while. If it's like the older cars, it'll start to bubble when the a/c oil soaks in. This will be a good test for anyone else wanting to try it.
Received 2,673 Likes
2018 C5 of Year Finalist
Looks good. I've seen some C5s where the owners have applied a clear over the interior to match the exterior paint. They also remove the light/wiring and fill in the plug holes.
I plan to add an embroidered hood liner.
You got lucky bud! Your paint looks really good on the hood. I have tons of unfinished blue marks under my yellow hood, and it looks like a$$. Definitely better than the hood liner, but looks ghetto. Going to have it painted, holes filled and cleared this summer though!
As far as I know, it's for fire suppression mostly. I'm sure it helps with heat a bit too, but I wasn't worried about removing the liner. With the Z06 screens and the engine bay getting good air while moving (my Z is mostly a highway cruiser, not a DD so it doesn't idle much and get really hot), I'm not worried about the paint. It will be just fine. After driving the Z for a while, I can open the hood and touch the intake and it's cool...barely lukewarm. If the heat would cause the paint to bubble, wouldn't it also affect all the cheap plastic parts under the hood? I'm not sure...
I have actually been wanting to do this for a long time. The reason I haven't done it is that I thought the cabin noise would be a lot louder. Also the poster who expressed concerns about oil spray was a concern also. Toque... any noticeable sound difference inside the cabin?
I'm surprised the paint under there looks that good. I got a used black one off a 99 and it wasn't all that pretty under the insulator. It just had black basecoat with some clear overspray around the edges. It was obvious factory paint. In any case, the guy gave me perfect insulator with it and it's going on with the light ect. A lot of people say a car isn't the same after it's wrecked. I'm out to put it back original as possible and prove em wrong....well the paint will be better
did this with yellowvette837's hood...had the holes filled and the hood shot and clear coated to look like the top....no different than the finished underside of my MCM hood...
I have not driven it yet with it removed. I'll find out as soon as the sun comes out.
With all the aftermarket hoods on here with no liner I think I would have heard of a complaint in the last 12 years I have been surfing the C5 forum. Your the first I have heard mention it so far.
Not sure.... I guess I will find out. I usually leave the hood cracked open in my garage anyways. All the aftermarket hoods with no liners don't seem to have issues that I have heard.
Thanks guys !
Toque
here is a shot of yellowvette's hood...painted in July 08...daily driver
and the pic I posted above in my previous reply of yellowvettes car has been like that for 3 years or more (see edit above 4 years daily driver)
Location: This is not a Song, It's an Outburst: Or, The Establishment Blues; Sixto Diaz Rodriguez
It does look good... I removed my liner a couple of years ago, I did add some decals to the underside, but haven't noticed any difference in the paint, or, decals peeling off, and it gets hot as hell down here. I haven't noticed any "oil spray," or noise increase.
people forget that many people get the coil covers painted etc...
